Author Topic: What are these 3 and what do they do please.  (Read 4442 times)
Big Ada
« on: November 07, 2015, 04:14:29 pm »
And this.
and this.
Thanks for your help.
Len.
SteveB66
  • Boats are chillin!!
Re: What are these 3 and what do they do please.
« Reply #1 on: November 07, 2015, 06:10:12 pm »
The wiper type board with all the wires looks like a Tamiya speed controller, but it is missing the ceramic heatsink.
The rest aint got a clue.
« Reply #2 on: November 07, 2015, 06:16:56 pm »
Nude servo. ???
Action P79 ?? 10 A esc.
sparkey
« Reply #3 on: November 07, 2015, 06:24:37 pm »
 :-)) The first is a servo without case,the second is a mechanical speed controller and the last a P79 maybe?....Ray. :-))
inertia
« Reply #4 on: November 07, 2015, 09:48:02 pm »
Whoever wrote Action P79 on the top of the little drawing in the picture was correct, for 'tis one of those. I would agree with the verdicts on the other two items i.e. bin food.
DM
« Reply #5 on: November 08, 2015, 10:16:22 am »
The first one is a servo motor and board with a physically broken position sensing pot.  This could be replaced with a fresh one like this - http://www.maplin.co.uk/p/10k-andohm-carbon-vertical-sub-miniature-fully-enclosed-preset-potentiometer-uh16s - at minimal cost even from Maplin and then be used as a combined mini motor and speed control.  Possibly a previous owner intended that and managed to pull the top off the pot thus losing the wiper assembly (important bit).
Big Ada
« Reply #6 on: November 08, 2015, 04:53:00 pm »
DM
Thanks for that, so what does it do please.
Len.
« Reply #7 on: November 08, 2015, 05:05:55 pm »
It's an electronic speed  controller Len.
Will control the speed of a motor when
connected between the receiver and the motor.
inertia
« Reply #8 on: November 08, 2015, 06:14:30 pm »
Len.
It doesn't do Google checks. Neither, it appears do you, so here's one I did earlier. http://www.componentshop.co.uk/p79-condor-10-2-autoset-computer-speed-controller.html
DM
wombat
« Reply #9 on: November 08, 2015, 06:45:17 pm »
Item 1 - Servo modified for continuous rotation (or broken)
Item 2 - Would need to investigate further, but I suspect it is a servo controlled reversing switch
Item 3 - P79 Electronic Speed Control
Wom
« Reply #10 on: November 08, 2015, 09:39:25 pm »
Wom
Agreed, Item 2 is indeed a Tamiya 3 Step Forwards and Reverse Speed controller, operated by a servo it has 3 forward and 2 revers speeds
There should be a ceramic resistor that connects to the 3 purply blue wires:-
Thick red & Black go to the battery
Smaller red/Black with red connector go to power the Receiver
Green & yellow go to the motor
Page created in 0.014 seconds with 17 queries.
