Author Topic: Power set for 1:24 scale Schooner  (Read 2120 times)
Nellybob
  • Great resource!
    • Pond yacht restoration.
« on: December 05, 2015, 01:02:04 pm »
I'm looking to fit a power set to a 1:24 scale Schooner "Kathleen" based on the Schooner Kathleen and May. The hull is 45 inches long and is fitted with a rudder.
The full size ship was fitted with an auxiliary engine in the 1950's. I will be fitting sails with a winch but also wanted to run her with a motor too.
I was thinking about some of the Robbe units for their Schooner range.......advice please.
Neil.
More pictures of the schooner http://fishingluger.blogspot.co.uk/
A solution will present itself.
Re: Power set for 1:24 scale Schooner
« Reply #1 on: December 05, 2015, 01:36:17 pm »
I looked at this briefly a while back, and so my memory may be a bit in error. But I am sure others will jump in.
If memory serves. The auxiliary drives were retro fitted. Even though it sounds like Kathleen is fitted with two props, I have seen several examples with only one prop that emerged through the hull to one side of the keel. The ones I saw were on the port side. Maybe just coincidence that I only saw single props on the port side.
I think a retro fit of one of the Robbe units would be easy. You don't need a lot of power, as it really is just an little extra push.
My only thought at the time was changing to a brass prop for scale appearances.
I looked at the Robbe units, but they did seem a bit expensive, but considering they can include motor, gearbox, shaft, and prop, perhaps not that expensive.
My thoughts at the time were to have aux drive to push her nose through a tack in light or difficult winds, as I used to sail in a pond surrounded by high rise flats, and the wind could change in a few meters. The other thought was to bring the boat slowly home if the winds died completely.
rickles23
    • Royal Navy Commandos
« Reply #2 on: December 05, 2015, 02:28:52 pm »
Tigertiger's memory is ok.
Attached photo is a more modern version.
« Reply #3 on: December 05, 2015, 02:49:38 pm »
Kathleen May has one engine driving a pump to two
hydraulic motors
This was a late fit.
Before that only one wing engine  was fitted.
I would have thought it would be better on the
starboard side for coming alongside port side to
for unloading.
Just my thoughts.
Page created in 0.334 seconds with 17 queries.
