Author Topic: y lead servos  (Read 2948 times)
regiment
y lead servos
« on: February 04, 2016, 11:13:35 am »
  is it possible to run two servos from one channel  if so would any body like to swap a y cable for two new 12 inch straight ones   thanks
Robotnik
  • Model Boat Mayhem, it's not too bad
Re: y lead servos
« Reply #1 on: February 04, 2016, 11:25:05 am »
   I've got spare Y leads, I bought 10 last year.
If you PM me your address I'll pop one in the post later today.
No need for swapsies.
Tug Fanatic
Re: y lead servos
« Reply #2 on: February 04, 2016, 11:32:58 am »
In an emergency if you have 2 ordinary servo extension leads, solder and a bit of heat shrink you can make your own. There is no electronics involved just join the red lead in from the receiver to two red out to the servo & do the same for the other two colours.
Don't do the reverse & try mixing two channels on the receiver into one servo.
Bob K
  • Bob K
Re: y lead servos
« Reply #3 on: February 04, 2016, 02:55:52 pm »
Yes, provided you do not exceed the maximum output rating of the receiver.
For example, I have a ship with a regular rudder at the stern plus two mechanically inter-linked rudders at the bow.  In this case I used a reversing Y lead because when the regular rudder turns to port I required the bow rudders to also turn inwards to port.  No problem.  Works well.  However I am not using all channels on the receiver.
Re: y lead servos
« Reply #4 on: February 05, 2016, 09:25:52 am »
Don't forget, though, that the reversing Y lead DOES have an electronics box in it.  As stated in a previous post, a "straight" Y lead is just one receiver plug wired colour for colour to two line sockets.
Page created in 0.092 seconds with 18 queries.
