Author Topic: about the size of bricks...  (Read 3782 times)
Krishna
  • aqua plannerrrr....................
« on: March 22, 2016, 05:18:28 pm »
Good evening Friends..
want to make some dioramas in 1:35th scale.. and 1:72.. so can anyone tell me the size of a brick, in 1:35 and 1:72.. will be  a great help.. million thanks in advance..
in sheer ecstasy of being a powerful,mushy,masculine trans woman of substance...
Brian60
Re: about the size of bricks...
« Reply #1 on: March 22, 2016, 05:35:53 pm »
English house bricks are approximately 215 x 102 x 65. So in......
1/35 that is 6.14mm x 2.9mm x 1.8mm
1.72 that is   2.98mm  x  1.41mm x 0.9mm
Good luck with them. Although if you check out some of the suppliers for plastic models world war 2 era tanks and stuff, they do plenty of accessories like bricks etc already cast to scale.
Krishna
« Reply #2 on: March 22, 2016, 05:52:23 pm »
million thanks Brian.. i am starting from a wind mill, pentagonal farm house and a country house near river.. thanks once again..
Klunk
« Reply #3 on: March 22, 2016, 07:13:35 pm »
You can buy bricks in 1/35 and 1/72 scale with grey cement! Check eBay
full time penguin
TheLongBuild
  • Build em, and play hard..
« Reply #4 on: March 22, 2016, 08:38:00 pm »
Why buy when krisna is more than capable of making them and probably better than that you can buy...
« Reply #5 on: March 22, 2016, 09:15:32 pm »
If nothing else, it provides a suggestion of where such things can be bought if a modeller does not want to, or cannot make them.
A way of making walls with bricks, or stones is to draw the pattern onto Depron foam. This is what Supermarket chilled pizzas are packed onto as a stiff base and ultra light RC aero modellers use and can be bought in sheets of varying thicknesses.
Here are some examples:
http://armorama.com/modules.php?op=modload&name=SquawkBox&file=index&req=viewtopic&topic_id=231321&page=1
http://mytinyworldfromhungary.blogspot.co.uk/2011/03/stonewall-tutorial.html
Some of the scenes are gorgeous.
Krishna
« Reply #6 on: March 23, 2016, 06:15:54 am »
Good morning Friends..
million thanks to all once again.. and for the great links..
started working on.. with papers.. laminating to a good thickness..
TailUK
« Reply #7 on: March 23, 2016, 10:22:05 am »
In 1/72nd scale Metcalfe models do brick card which is excellent.
rickles23
    • Royal Navy Commandos
« Reply #8 on: March 23, 2016, 02:23:19 pm »
Hi all,
Was not the Motorflotte tug referred to as a Brick?
Big Ada
« Reply #9 on: March 23, 2016, 05:05:41 pm »
Hi all,
Did we ever see that Sail?.
