Author Topic: Smoke generator  (Read 5599 times)
Gopher
Smoke generator
« on: April 04, 2016, 01:37:07 pm »
Hello all, I am thinking of putting some smoke in my tug, there is one on fleabay at £45 with the orange res that just uses water has anyone had one of these and if so are they any good, I used to have a graupner one in but was never impressed with it
inertia
Re: Smoke generator
« Reply #1 on: April 04, 2016, 01:49:59 pm »
This is new on the market. Steve's stuff is A1 in my experience. He will be at the Coalville Show next weekend, which isn't too far from Mansfield.
Dave M
http://www.modelboatbits.com/MIST-UNIT
Gopher
Re: Smoke generator
« Reply #2 on: April 04, 2016, 01:59:26 pm »
I have looked at that one also my only problem is the height the other one is 72mm high which will sit exactly where it has to below the funnel but 110mm is going to be very tight
David Shaw
Re: Smoke generator
« Reply #3 on: April 04, 2016, 07:25:49 pm »
At my boat club lots of the club members only use the orange one from Model Boat Smoke. All work ever time, with great smoke effect.
You can buy them on his web site www.modelboatsmoke.com or his Ebay site. Then again at one of the shows he exhibits at.
David
David Shaw
Gopher
Re: Smoke generator
« Reply #4 on: April 04, 2016, 07:32:58 pm »
Thanks for that, I shall get one ordered, I know then it will fit where I want it
Buccaneer
Re: Smoke generator
« Reply #5 on: April 04, 2016, 07:34:22 pm »
I have one ready for my Tug rebuild. It works very well on the bench and the big advantage is that it is all 12V. If you have a steam type boat it is probably nothing rapid, may be quite big. I use 12V SLA Battery and run everything through Action P92 or P107 Power Distribution Board.
Gopher
Re: Smoke generator
« Reply #6 on: April 04, 2016, 08:12:23 pm »
Mine will be going in a 1:20 scale tid tug all the wiring is in place though an rc switch so I will be able to turn smoke on and off from handset
cos918
Re: Smoke generator
« Reply #7 on: April 04, 2016, 08:48:17 pm »
why not build your own and save a a ton of cash .
Mister about 3 pound each
fan 1 pound
12v to 24 v converter about 3 to 4 pounds each.
box depends on size .
all avaible on ebay
john
Gopher
Re: Smoke generator
« Reply #8 on: April 04, 2016, 09:06:26 pm »
Just had a quick look on eBay, I think I will leave building it to somebody who knows what they are doing
nivapilot
  • re-invented rc boater
radiojoe
Re: Smoke generator
« Reply #10 on: April 08, 2016, 10:52:20 am »
http://www.ebay.co.uk/itm/New-Air-Humidifier-Ultrasonic-Mist-Maker-Fogger-Water-Fountain-Pond-Atomizer-/191744453948?hash=item2ca4dc2d3c:g:bW8AAOxyLN9ShHqm
Is this the type of fogger/ mister unit John?
The trouble is that one needs to be submerged in water, kind of defeats the object of a boat, I suppose it could mark the place where the boat sank. %% %% {-) {-) {-)
nivapilot
Re: Smoke generator
« Reply #11 on: April 08, 2016, 11:33:43 am »
I ordered one anyway Joe, thinking that it will either fit in a box and be covered with water, or I'll cut it open, fit disc in the bottom of a box and the control circuit outside.
At that price I can experiment and try to get a working unit, even if it doesn't work out, i haven't wasted much cash.. :-))
Gopher
Re: Smoke generator
« Reply #12 on: April 08, 2016, 02:40:53 pm »
It looks the same as the one I received in the smoker I got needs 24v the same, mine ragged in after about 15 mins,  I'm in the process of sorting it out with seller, he is sending me a new one, it did look ok when it was working, it might be worth me ordering a couple as spares, as well as a couple of 12v to 24v units just in case,  the set up looks pretty straight forward the water tank would be reusable
craggle
  • Boaty McBoatface
Re: Smoke generator
« Reply #13 on: April 08, 2016, 03:24:39 pm »
I bought one and it worked fine in a bowl but then I hid it inside a small margarine tub.
It melted a hole pretty much instantly in the plastic lid right above the centre of the fogger unit so be careful what type of plastic you make the box from or maybe it was due to the plastic being too close to the unit?
Craig.
Model Slipway Envoy tug built.
Huge Lifeboat under construction.
cos918
Re: Smoke generator
« Reply #14 on: April 08, 2016, 06:28:51 pm »
Hello thats the one. water needs to be about 5mm above the top of the unit. Note they run on 24v
john
cos918
Re: Smoke generator
« Reply #15 on: April 08, 2016, 06:32:25 pm »
made a few smoke units. the biggest had 3 mister and 2 fans. really pumped out the smoke .
IKB
Re: Smoke generator
« Reply #16 on: April 08, 2016, 11:50:36 pm »
Hi Gopher,
I built my own custom cold smoke unit from parts off eBay to go in my Clyde Puffer, build thread below:
http://www.modelboatmayhem.co.uk/forum/index.php/topic,52469.0.html
Good luck with yours,
Alex
Page created in 0.612 seconds with 18 queries.
