Pages: 1 2 3 [4]   Go Down
Author Topic: Diva scratch build  (Read 26182 times)
Starspider
Re: Diva scratch build
« Reply #75 on: May 20, 2016, 11:17:45 pm »
She looks a proper cruiser Joe very nicely done from pen to paint.
Her tumble home on the stern view suits her perfectly to my eyes, well done sir  :-))
canabus
« Reply #76 on: May 21, 2016, 07:58:58 am »
A top job, you shown us nice build with a few lovely pics of the boat running.
What motor did you end up with and prop combination.
I see that ewe are planning a few prop experiments with plastic ones.
I have found the metal ones better in the same size and pitch.
radiojoe
« Reply #77 on: May 21, 2016, 08:59:15 am »
She's got a 1100K outrunner that's seems well up to the job and a 35mm two blade plastic prop, I too prefer brass props and she will have one eventually but plastic ones are cheaper to experiment with. :-))
canabus
« Reply #78 on: May 21, 2016, 10:30:16 am »
Totally agree with you prop idea's.
The motor must be a 28mm as the 35mm one's I have run 40mm props.
Can-a-bus
radiojoe
« Reply #79 on: May 21, 2016, 11:44:25 am »
I've just found a 30mm three blade brass prop in my spares box, I'll try it out at my local lake on Monday just as a comparison.
« Reply #80 on: May 21, 2016, 06:39:57 pm »
Nice Stern!
radiojoe
« Reply #81 on: May 24, 2016, 12:55:07 pm »
Tested the 30mm three blade brass prop but performance was somewhat reduced, so I went to the local lake again today and bought a 40mm X type prop on the way, and now she has the performance I was looking for, very respectable speed but in keeping with the scale, very happy with her now great fun, I can see her sailing often. Again thanks for your interest and kind remarks.  :-))
« Reply #82 on: May 24, 2016, 07:27:10 pm »
No worries Joe, your projects (like many on here) are interesting to read and study. It beats watching talent competitions thousands of timesover!
radiojoe
« Reply #83 on: November 16, 2016, 02:30:32 pm »
The last time Diva was sailed the performance was quite acceptable, but I got the feeling that the turns were a bit vague like the rudder couldn't handle the trust from the X type prop I concluded that I hadn't made the rudder large enough, so I set out yesterday to make a larger one, simple things to make so I thought this may help any new comers to the hobby so they can see you don't have to buy pricey commercial stock rudders when you can make them for a few pence.
The centre lamination is 1.5 mm. styrene and the outer ones are 1mm. styrene the shaft is 3mm. brass rod, and I've used a water proof epoxy,
Joe :-))
« Reply #84 on: November 16, 2016, 10:26:37 pm »
Looking forward to the results of your latest tests Joe - hope you get the performance you're looking for. :-)
radiojoe
« Reply #85 on: June 16, 2017, 05:50:22 pm »
Just noticed it's been 7 months since I made the larger rudder and only just got round to trying it out yesterday, the turning was so sharp I had to adjust the end points on the Tx to 50 % because I tried a hard turn at full throttle and it turned so tight that she made a vortex inside the turn and nearly submarined into it, when I brought her back in she had a cockpit full of water but dry inside, so with the new Tx settings I can thrash her all over the lake and she just takes it well.
Joe
« Reply #86 on: June 16, 2017, 09:12:09 pm »
Phew! That was a near miss.
Have lots of fun.
radiojoe
« Reply #87 on: June 16, 2017, 11:33:56 pm »
Sure was Ian, I've never seen a boat do that before it simply made a vortex on the sharp turn and almost fell into it, if I had left the power on I think it would have, the reduce rudder movement has cured it.
Joe
Pages: 1 2 3 [4]   Go Up
Page created in 0.17 seconds with 18 queries.
