Author Topic: TVR1A linkage  (Read 4806 times)
kiwimodeller
TVR1A linkage
« on: May 08, 2016, 10:59:49 am »
I am sure I have seen a post about connecting the TVR1A forward/reverse lever to a servo but no amount of searching brings it up, just heaps of other posts about the engine. Can anybody give me a link to the previous thread? Alternatively I am looking for ideas to connect a servo in the stern of the hull to the reverse lever. Some type of bellcrank will be needed and it would be nice if someone who has done it all could offer advice on linkage ratios, size of servo etc. thanks, Ian.
Jerry C
Re: TVR1A linkage
« Reply #1 on: May 08, 2016, 05:44:30 pm »
This is how I did it. Copied from Jerrys steam launch wear in steam page two. About 9 pages from the end of the thread.
     This morning my new engine driven feed pump arrived. I'm very pleased with it. So I'm going to take a break from the boat and get the steam plant boxed off. I made a start by removing the boiler ,gas tank and engine from the tray. Out 0f a 13 amp plug pin I cut, ground and filed a lever to attach to the reversing selector shaft for a servo to act on. I removed the spring steel reversing rod from the engine. I turned down the brass handle until it was a good fit in the plug pin and soft soldered it together. I had filed a step on the pin to locate the lever on the link connector. I reversed the spring steel rod and replaced it in the engine but with the detent bar swung through 180 degrees so now the rod slides on the smooth side of the detent bar. Fitted a clevis and now I have a simple reversing control.
Jerry.
Report to moderator     Logged
kiwimodeller
Re: TVR1A linkage
« Reply #2 on: May 11, 2016, 09:28:08 am »
Thanks for that Jerry, I am sure that was the post I was thinking of. Regards, Ian.
Jerry C
Re: TVR1A linkage
« Reply #3 on: May 11, 2016, 10:07:41 am »
Sorry matey, for some reason site won't accept previous site pics, saying not correct type of jpg. If you trawl around on wear's thread the pics should clarify matters. Best of luck.
Jerry.
steam up
Re: TVR1A linkage
« Reply #4 on: May 27, 2016, 11:16:26 pm »
Check this page out you will find a number of different approaches  :-))
https://www.facebook.com/Modelsteamboats/
Landlocked
Re: TVR1A linkage
« Reply #5 on: January 05, 2017, 02:45:44 am »
kiwimodeller,
Here's my TVR1A linkage setup.  The arm is rotated on the replacement shifting lever (trimmed not to reach the notches on the otherside) a bit to allow for a better picture.  Servo pushes/pulls.
Landlocked
xrad
  • Keeper of the Sun Dried Tomato
Re: TVR1A linkage
« Reply #6 on: June 27, 2017, 01:18:15 pm »
I used a  dis-advantage right angle servo arm and two linkages on my Brookly tug.  The dis-advantage right angle servo arm has a short arm to servo via one link, and long arm to the TVR control lever. This will give the correct throw need to change position/direction. Standard servo will have enough force to easily move this set-up.
Bernhard
Captain Povey
Re: TVR1A linkage
« Reply #8 on: June 30, 2017, 09:22:32 am »
Her is a picture of my set up. Hope it helps. Graham
steam up
Re: TVR1A linkage
« Reply #9 on: June 30, 2017, 09:45:03 am »
I use a very similar set up but mount the servo below deck level  :-))
Page created in 0.574 seconds with 18 queries.
