Hi All
You can make to suit any number of motors.
We only did 3 on the first two, but, I think you can fit about 6 different sizes.
Also if you made the shaft hole larger and made sleeves for different size shafts you make the tool more versatile.
GOOD 3D PRINTER PROJECT FOR SOME ONE!!!!
It's the idea for the alignment tool and what motors I had in the workshop.
I have a few brush motors but I do not use them.
The 35mm brushless screw holes are the same as the 540 motor.
My first brushless was in an old Tamiya dune buggy Falcon(90 watts(22000rpm) up to 550watts(26640rpm)) and dropped 50 grams changing to a 3S 2650mah Lipo, so it's total insane to drive and runs for over an hour.
By that time the driver requires a nap!!!
Bob, 2.5mm silicon fuel tubing (OR005-00601) from Hobbyking in one metre lengths(about $2 AU dam cheap).
