Author Topic: radio scanners  (Read 4055 times)
ddraigmor
radio scanners
« on: August 06, 2007, 05:53:23 pm »
Currently own two - GRE's - PSR 295 (which does most of what's out there but bought specifically for Military Airband) and a PSR 282, which does Civvy airband and good on marine VHF.
Was the proud owner of many HF sets as a listener, the last being a Grundig Sat 800 which was sold six months ago.
Any others into 'scanning'?
Jonty
Weeds
Re: radio scanners
« Reply #1 on: August 27, 2008, 03:47:01 am »
Coast Guard VHF and Cape Cod Maritime VHF listener here. Anybody can listen online. In fact right now there is a report of "ref flares" and "all boats are instructed to keep a sharp look out" DSC alert received (boat in distress)...i hope they are ok...
Faraday's Cage
  • Change is inevitable, except from a drinks machine
Re: radio scanners
« Reply #2 on: August 27, 2008, 09:33:58 am »
Weeds, Have you got a link for this please.
FC.
Weeds
Re: radio scanners
« Reply #4 on: August 27, 2008, 10:26:35 pm »
 Red Flare spotted in Falmouth Harbor. DSC Alert. Yesterday. Boston Sector Coast Guard VHF. http://www.soundupload.com/listen/5mys1idywa1wb7t3
ddraigmor
Re: radio scanners
« Reply #5 on: August 27, 2008, 10:56:30 pm »
Weeds,
Thanks for the PM. A full list of US Marine VHF channels is here:
http://www.navcen.uscg.gov/marcomms/vhf.htm
Usually, a scanner will either come with simply channel numbers eg 01 and you have to manually input the frequency you want stored on it. For example Channel 1 could be used as Marine Channel 16 - 156.800. Modulation is FM.
Some scanners will show the frequency readout. eg. Mine is 'banked' with mil airband, civ airband and marine VHF. I have VHF Channel 16 Marine on my channel 40 though the readout shows 156.800 FMN (FM Narrow). I also have a dual watch so that, if I program it, it will pick up two channels by scanning both. I make one usually Channel 16 and the other our primary lifeboatr working channel (also HM Coastguard) which is Channel Zero (156.000). I can also make a priority frequency the 'select' one so that if it is scanning, then the priority will come in every two seconds, but lock when it gets a signal.
If you want to say what scanner you have I may be able to help further.
The UK does not allow re-broadcast of marine VHF but I have got links for the Dutch system, which also uses AIS so you can hear and 'see' the ships on an auto- refresh map. It is situated here:
http://www.scannernet.nl/AIS%20Google%20Online%20DSC.html
and here: http://members.home.nl/krid/livescanner.html
There is an AIS map of the US at: http://ais3.siitech.net/VTSLite/AView.aspx but I don't think it has VHF - but you could use a map which shows ships movements (known as AIS) and listen to your scanner at the same time?
Jonty
