Author Topic: Length of receiver aerial wire  (Read 3891 times)
inertia
« on: June 17, 2016, 11:20:57 am »
A quick question. I have three of these receivers but have shortened all of the aerials to connect to whip antennae. I've calculated the probable length of the full-length wire (as supplied) as 92cm, but can anyone who has one just confirm this for me? Nominal frequency is 40.675MHz.
I begin to mistrust my maths these days!
Dave M
C-3PO
Re: Length of receiver aerial wire
« Reply #1 on: June 17, 2016, 11:46:13 am »
92cm would be 1/8th of the wavelength @ 40.675Mhz
inertia
« Reply #2 on: June 17, 2016, 12:16:54 pm »
Yep - that's what I got. 10/10?
Seems a bit on the lengthy side but I seem to recall that they were originally.
Any confirmation of our calculation from owners?
Dave M
C-3PO
« Reply #3 on: June 17, 2016, 12:23:53 pm »
Dave,
Hitec HP-2RNB - 104.5cm tip to case
Robbe Futaba - FP -R118F 98cm tip to case
Just to confuse things!
inertia
« Reply #4 on: June 17, 2016, 12:38:39 pm »
Yeah - many thanks for that, C3P0...  :o
I reckon 92cm will do, don't you? After all, we don't need out-of-sight range for our particular toys, innit?
Ta, m'duck.
Dave M
unbuiltnautilus
« Reply #5 on: June 17, 2016, 03:58:42 pm »
I have two 40mhz HFS-04MI+ Rxs in my grubby hands, 945mm and 965mm respectively, tip to casing.
roycv
« Reply #6 on: June 17, 2016, 05:08:14 pm »
Hi all, as long as there is enough of it, it does not seem to matter.  I usually cut my Rx aerials to about 6 inches long and fit a gold plated connector, then the rest of the aerial is incorporated into the model.  If I can, I have a soldered wire connected to a mast, part of the mast I make of brass tube with some wire and a matching connector at the end.  So there is usually about 3 feet of it, which certainly works for me.
Then if I need to change a Rx I can unplug it.
regards Roy
inertia
« Reply #7 on: June 17, 2016, 06:33:25 pm »
Thanks, Roy, but I already did all of that. The current situation is reversing it so that I can offer the receivers for sale. I've settled at 92cm.
DM
roycv
« Reply #8 on: June 17, 2016, 11:09:41 pm »
Sorry DM did not pick that up from your Initial post., when you are finished will you see the join?
regards Roy
inertia
« Reply #9 on: June 17, 2016, 11:18:13 pm »
How dare you, sir!!  >>:-(
Nah - I took 'em out of their cases first and used all new wire, so there ain't no join except the one to the PCB........but let's keep that a secret, eh?  %)
DM
Page created in 0.451 seconds with 19 queries.
