Author Topic: Fairmount kit query ?????  (Read 2652 times)
Vts99
  • Clydebuilt = best built
« on: June 22, 2016, 07:30:16 pm »
Hey guys back again lol
In the kit there's a piece of copper round bar around 5mm diameter and about 450 mm long
I can't see what it's for on the plans and jus wondering if any of the builders would know or am I just missing something on the plan
Graeme
TailUK
Re: Fairmount kit query ?????
« Reply #1 on: June 22, 2016, 07:46:19 pm »
According to the instructions that's Part 271 and it's used to make Goose-neck vents  See figure 25.
http://billingboats-direct.com/estore/instructions/billing/bb506.pdf
Vts99
« Reply #2 on: June 22, 2016, 07:59:14 pm »
Hi thanks for that but it looks more like 272 going by the length required showing 5mm x 442mm but can't see it on the sheets
Vts99
« Reply #3 on: June 22, 2016, 08:02:49 pm »
It's OK got it now jus zoomed in on your link and found it . It's the fake fire monitor supply pipes up to bridge roof
david48
« Reply #4 on: June 22, 2016, 11:21:26 pm »
thy need not be fake . I did away with the metal mine was a length of alli rod . Bending and getting the angles rightwas a bit of a take on .  I  used evergreen plastic pipe the same dia. made up templates and then cut and glued then . To get the angles around the superstructure . I turned my bends using the Lobster Back method its a bit fiddly but you get a more realistic turn . I still have the templates but if I am not exactly the same as yours thy will be no good . After I made them up I pressure tested them so if at a later date I wanted to use them I could . please PM me if you need clarification on lobster back pipe turns .
Regards David
Vts99
« Reply #5 on: June 22, 2016, 11:43:17 pm »
Thanks David.  I'm not sure if I'm going to fit them at this time as I'm planning on having working monitors so will be running piping up internally . May jus do it for accuracy to the real ship at a later date
Graeme
Page created in 0.019 seconds with 18 queries.
