Author Topic: Cutting Copper clad board  (Read 4163 times)
cos918
« on: July 01, 2016, 09:21:44 pm »
Hi all . I have to cut a big shape out of double sided copper clad board. I think it s fibre glass in the middle . The whole lot is about 1.5mm thick . Any one got any tips
john
Onetenor
Re: Cutting Copper clad board
« Reply #1 on: July 02, 2016, 12:42:23 am »
john
 Scroll saw or fine hand fret saw. Maybe just maybe a jig saw with fine blade .
Fubar
« Reply #2 on: July 02, 2016, 07:19:59 am »
Rough cut to shape with Tin Snips then finish to size on a belt sander
Plastic - RIP
  • Inactive
  • Bobbing Along!
« Reply #3 on: July 02, 2016, 08:33:50 am »
And wear a dust mask & glasses - nasty fibreglass dust!
nivapilot
  • re-invented rc boater
« Reply #4 on: July 02, 2016, 08:43:44 am »
If it's electrical double sided component board, the inner core will probably be paxolin, which is a little bit on the brittle side.
I would cut rough with coping saw,(fine blade) and finish with sanding belt/discs/drums.
inertia
« Reply #5 on: July 02, 2016, 09:01:35 am »
I would first mark out the shape to be removed with a scriber, making sure you really give it some pressure to score the copper cladding. The board could be made from epoxy-glass laminate; you can quite easily see the weave in this and it will be a much paler brown than paxolin (or even a slight green colour). Chain-drill a series of holes around the inside of the scribed line; join them up with either a scroll saw or fretsaw and then use a fine file or a Dremel to grind the glass back to the scribed line. Do wear a mask when working on epoxy-glass sheet - it's nasty stuff if you get a big snort of it!
DM
cos918
« Reply #6 on: July 02, 2016, 09:41:37 am »
Hi All
Thank you for the good advice . I have a few scrap bit so I will see how the above ways of cutting the board work .
john
Brian60
« Reply #7 on: July 02, 2016, 12:51:54 pm »
Dremel router
or if you have the cash a cnc router {-)
wombat
« Reply #8 on: July 02, 2016, 10:45:19 pm »
If the core is white/greenish and translucent it is probably FR4 fibreglass. If it is brown it is SRBP which is easier to cut
tobyker
« Reply #9 on: July 02, 2016, 11:58:28 pm »
I'd use a piercing saw. Like a coping saw, only finer teeth.
steamboat66
  • maybe it will float!
« Reply #10 on: July 06, 2016, 10:46:51 pm »
i have roughed out with the guillotine at work for a multirotor frame. if sawing, mind the dust, and make sure you have some more blades. fibre glass is very abrasive.
Page created in 0.027 seconds with 17 queries.
