Author Topic: Tyne Class Running Gear  (Read 2520 times)
MGSweeney
  • Just getting into model boats
« on: July 18, 2016, 08:28:59 pm »
Hi all,
New to model building and the Tyne Class will be my first build (originally planned on the 'Moorhen' buoy tender). I have the vac formed hull and plans from myhobbystore but I need some advice as to what sort of running gear I require, the plan states 38mm props but not sure what size motors/batteries etc.
Can anyone help?
Kind Regards,
Michael.
petermun
Re: Tyne Class Running Gear
« Reply #1 on: July 19, 2016, 10:31:07 am »
Hi,  I have recently completed a semi-scratch 36 inch Tyne class.   I used two 480 fully suppressed brushed motors driving two 35mm props, with an Mtronics 15 Amp ESC.   It will run on Nihms or Lipos from 7.2 volts to 8.4 volts.   It goes well and is fast enough for me ,but if you are into brushless motors it could go faster.   Pete
MGSweeney
« Reply #2 on: July 20, 2016, 09:23:30 pm »
Thanks for your help, i'll look into this.
Page created in 0.211 seconds with 17 queries.
