Author Topic: Oil separator/condenser  (Read 2503 times)
rhbrook
« on: July 27, 2016, 02:46:14 pm »
I am now in the process of starting to construct an oil separator/condenser.  The size is approx. 30 mm dia x 70 mm.
Can anyone recommend the max/min dimension from the bottom of the 'discharge' pipe to the top of the base so as to allow easy discharge of the 'sludge'.
Should the bottom of the discharge pipe be square or would it be preferable to be cut at an angle?
Roger
rhavrane
  • Steam passionate collector
Re: Oil separator/condenser
« Reply #1 on: July 27, 2016, 07:10:54 pm »
Bonjour Roger,
The size of an oil separator depends on the machine you will use. My Stuart D10 need more volume than my 2 cc machines and to my opinion, 30 x 70 is too small. 50 x 80 are my minima for my smaller machines.
The pipes should be on the top, in order not to slow down the steam and create a conter pressure for the machine if the water would feel them and not face to face to oblige steam to go in the separator before its exhaust. If you had to put the pipes face to face, a little separating plate should be soldered between them in the separator before closing it.
Example : https://www.youtube.com/watch?v=3jombigGCM8
https://www.youtube.com/watch?v=jw_VB728ahk
Raphaël
Bernhard
« Reply #2 on: August 06, 2016, 07:16:57 am »
rhbrook
« Reply #3 on: August 07, 2016, 01:35:42 pm »
Thank you all for your input and I shall incorporate your advice.  I intended following the layout shown by Keith Appleton/Main Steam Models in the design.
Roger
Page created in 0.315 seconds with 17 queries.
