Author Topic: TAMCO 6 ch tx and receivers  (Read 3229 times)
KevinM
« on: August 07, 2016, 05:58:56 pm »
Being new to the hobby I was and am very pleased with the Tamco system I bought but I have 2 questions that maybe somebody can help with.
First the standard receiver is called a 7 channel, the power connects to the plug in the "7 channel" but it also has a signal line. I hear rumors that its for telemetry but the TX hand set does not seem to have any way of looking at it. What am I not understanding, it the 7th channel accessable or is it a possible future upgrade the company have not introduced yet?
Second, the 7 channel receivers are not as common as the four channel (is it 4?) so I was wondering if the TX will bind with anything other than the recommended 7 channel device?
KevinM
Re: TAMCO 6 ch tx and receivers
« Reply #1 on: August 09, 2016, 09:37:03 am »
Surprised nobody knows about this system. Cant find anything useful on the web either and the instructions are just a joke :)
TomHugill
« Reply #2 on: August 09, 2016, 11:08:41 am »
I've got the transmitter but no recievers, can you tell me where to buy them?
KevinM
« Reply #3 on: August 09, 2016, 11:17:05 am »
just bought a second receiver from this place but its not arrived yet so cant say anything about them, should be here next few days though
http://www.modelboatbits.com/RADIO-SETS/
« Reply #4 on: August 09, 2016, 11:19:42 am »
Steve @ Modelboatbits is one of the best traders to deal with. :-)) :-)) :-))
KevinM
« Reply #5 on: August 09, 2016, 03:30:30 pm »
Pleased to hear that Ned, he has some good items, his 4.8 batteries are very competitivly priced so I got one, an rx and a charger, fully intend to get more once the initial order comes through as this was my first "test" order with them/him
I understand that people may not have tried binding different receivers but im still bemused about this 7th channel and what its all about
barriew
« Reply #6 on: August 09, 2016, 05:21:25 pm »
Kevin
Provided the Tamco 4 and 7 channel receivers use the same modulation technique, then you will be able to bind them both with your transmitter. As for the seventh channel. If you use an ESC with a battery eliminator circuit (BEC) the you don't need (mustn't use) a separate receiver battery, therefore channel 7 could be used as a control channel IF you had a 7 channel transmitter. It is not uncommon to have more channels on the receiver than the transmitter - I suspect that is the way the ICs are made.
Barrie
Just done some Googling - and I don't see a 4 channel Rx listed anywhere. I did find a 3 channel which uses a different technique to your 6 channel.
KevinM
« Reply #7 on: August 09, 2016, 05:26:35 pm »
thanks for the reply Barrie, some of the fog is starting to lift
Page created in 0.182 seconds with 18 queries.
