Author Topic: Hello everybody I'm new to all this.....  (Read 6396 times)
neilesmith
  • What instructions?
« on: August 16, 2016, 11:27:04 am »
I have been modelling since I was old enough to squeeze a piece of plasticine, was an IMPS member & aeromodeller for many years & latterly built & flew many r/c helicopters. Recently built a 1/90th scale HMS Victory & 1/144th scale Destroyer. Needing another project I remembered a spare 8 channel rx & decided the Billings Calypso had plenty of scope for showing off with animations so that is now on my bench in the "getting my head around it stage". My 1st r/c boat so I will be asking lots of daft questions. Oh I'm 68 years old & live in the UK near High Wycombe so if any of you are close by I'd love to have a natter.
neilesmith
Re: Hello everybody I'm new to all this.....
« Reply #1 on: August 16, 2016, 11:42:38 am »
Blimey! My 1st post seems to have worked, I'm usually a complete dunce when trying to get on forums so this is a bonus.
My 1st question is about esc's. The supplier of my kit recommended 2 x HM-50 Waterproof Marine ESC with 2 x Mtroniks M500 6.0v - 12.0 motors which came with no instructions & so far have not worked at all so a beginners guide to making a Spektrum DX8 & AR8000 persuade them to turn 12v dc into some sort of rotary movement would be nice.
Thanks in advance
« Reply #2 on: August 16, 2016, 02:04:31 pm »
Hey Neil,
Welcome to the Mayhem!
Nice work on the first two boats!   :o
" making a Spektrum DX8 & AR8000 persuade them to turn 12v dc into some sort of rotary movement "
The two HM-50 Waterproof Marine ESC will do that for you.
Did you put RC into the Destroyer? - Same process!
If not, how can we help?
Also see: http://www.modelboats.co.uk/news/article/but-i-don't-understand-electronics/18054
« Reply #3 on: August 16, 2016, 02:40:13 pm »
The Calypso can be a rather "tender" model.
It is better to ignore the wooden base for the equipment and get the batteries low in the keel.
Keep top weight down to a minimum an if adding drives put the motor down in the hull with an extended shaft to drive.
« Reply #4 on: August 16, 2016, 02:59:13 pm »
Bob is right, Calypso tends to be a bit top heavy as a working model so you need to be aware of this. The topic is discussed in detail here:
http://www.modelboats.co.uk/forums/postings.asp?th=104760
neilesmith
« Reply #5 on: August 16, 2016, 03:26:44 pm »
Hey Neil,
Thanks for the compliment, & no the destroyer is static so this is my 1st r/c boat.
neilesmith
« Reply #6 on: August 16, 2016, 03:32:51 pm »
Thanks Bob, confirms my 1st impression that all the brass bits mean a lot of weight above the centre of gravity.
neilesmith
« Reply #7 on: August 16, 2016, 03:34:45 pm »
Thanks Colin, a useful link.
neilesmith
« Reply #8 on: August 16, 2016, 07:21:03 pm »
Problem solved & here for any other newbies is the solution ( the rest of you just sit back & smugly say obvious innit)
The ESC is a metal box with some wires sticking out of it, no switches buttons or clues in its appearance, oh & no documentation at all so plug it in (no audible clues like the helicopter ones) & waggle the throttle. Nothing.
Start over remembering that boats go backwards as well as forwards. Put the throttle to its mid point & if the ESC has a BEC circuit unplug the battery from the receiver ( if not sure assume it has, if not the receiver won't switch on). Connect power switch on and wait a moment so the electronics have a chance to initialise. Et voila!
« Reply #9 on: August 16, 2016, 10:52:11 pm »
« Reply #10 on: August 19, 2016, 09:01:18 pm »
If using two ESCs with BEC, not only remove the RX battery, but also winkle the red wire out of ONE of the 3 way plugs.  Saves any hassle from the BECs trying to regulate each other.
neilesmith
« Reply #11 on: August 20, 2016, 09:52:48 am »
Good point Malcolm, I should have mentioned that, thanks
« Reply #12 on: August 21, 2016, 04:04:13 pm »
I would say Very Tender <:(
20kph wind on the lake today with the odd 30kph gust
and a member's Calypso rolled over and sank.
Flat calm sailing only.
neilesmith
« Reply #13 on: August 21, 2016, 05:01:51 pm »
Oh s**t!
« Reply #14 on: August 21, 2016, 05:45:49 pm »
Exactly what the owner uttered {:-{ {:-{
neilesmith
« Reply #15 on: August 21, 2016, 07:41:39 pm »
I'm sure, was he able to retrieve the model?
Incidentally I have started a new thread under "Billing Boats Calypso" to record my build & share advice.
Neil.
jack
« Reply #16 on: August 23, 2016, 05:14:41 pm »
What a nice model of HMS victory I  have built many ship  models over the last 40 years HMS Diana was  one of my better models she is a 38 gun heavy frigate that Nelson once served on, I am new to this forum as well Thanks Jack.
neilesmith
« Reply #17 on: August 23, 2016, 07:22:49 pm »
Why thank you, I am quite pleased with it although as my very first ship model I made many mistakes but learnt a lot too.
My current build is now on another thread "Billing boats Calypso" if you are interested.
Page created in 0.027 seconds with 18 queries.
