Author Topic: adolph bermpohl Question  (Read 2737 times)
timgarrod
    • Alvaston Pirates Model Boat Club
« on: August 16, 2016, 09:54:47 pm »
after a bit a advice.
now that using all three motors on the adolph bermpohl. I noticed that my sound unit has a option for a 2nd motor input :).
Question is, would the middle engine only be used/started  only when needed or would all three be run all the time.(I'm only going to use it as a booster motor)
cheers
Howard Q
Re: adolph bermpohl Question
« Reply #1 on: August 18, 2016, 10:28:33 pm »
Hi. I have also rebuilt a model of the Adolph Bermpohl, and the same question raised  its  head, what I can gather the two outer motors were used for cruising speed and manoeuvring, the middle/third motor was only used to get somewhere in a hurry, on the Bermpohl the centre prop is a larger size than the two outers, giving that extra bit of grunt.
I hope this is of some help, she is a fine model and sits up well when opened up.
Howard Q.
timgarrod
« Reply #2 on: August 19, 2016, 05:53:05 pm »
Thanks Howard.
Used to only use the middle motor but was a pain to steer when the smaller boat was beening recovered but going to use tank steering so should help a bit.
roycv
« Reply #3 on: August 20, 2016, 09:40:47 am »
Hi, I have a twin screw boat and have a mixer in the transmitter.  You get excellent steering and also when stationary turning the rudders also powers up the motors and she turns on the spot.
regards Roy
Howard Q
« Reply #4 on: August 20, 2016, 05:29:44 pm »
Hi. If you don't already have a mixer fitted, I used the P94 for my Bermpohl it gives complete control over the two outer props with an option to control the speed of the third, a neat and efficient unit, first look at the price you think it is expensive but put together 2 speed controllers and a mixer bought individually it is well within the acceptable price range, plus all the electronics are balanced to one unit, I have 3 of these now in various models and highly recommend them. I have no financial interests in the suppliers, just a satisfied customer of many years, right from the early days of Action with Craig Talbot.
Howard.
timgarrod
« Reply #5 on: August 20, 2016, 05:48:18 pm »
thanks Howard,
Already got the escs and a mixer to hand. I been using Microsgryo esc's now for a few years and can't fault them. reminds me, need to get a few more for my Gato
Page created in 0.804 seconds with 17 queries.
