Author Topic: Servo application question  (Read 4100 times)
verithingeoff
    • Hofner Verithin Guitars
« on: September 27, 2016, 08:34:57 am »
Hi guys, looking for a bit of advice about a servo application. I want to turn a lever valve [steam] through 360 deg with a servo. Any ideas about how to?
Growing old disgracefully in Queensland
http://modelandtoysteamforum.myfineforum.org/
Re: Servo application question
« Reply #1 on: September 27, 2016, 08:50:39 am »
Replace the lever with a gear.  Servo city do a range of gears to output from a servo for their robotics customers, it should be possible to gear up to 360°, get any fine adjustment using a servo stretcher.
Ken G121
« Reply #2 on: September 27, 2016, 09:01:08 am »
Not sure it will work here but to to rotate guns I use a pulley system with a belt. If your servo has a 90 degree sweep put a large pulley on the servo and a smaller one on the item to be operated. If the large one is 3 times the diameter of the small one (ratio 3:1) then you get 3 x 90 degrees at the other end 4 times dis will give 4 x 90
Degrees = 360, as long as the drive belt does not slip this should work as long as the thing you are turning is low friction. I bond the large pulley directly to the servo arm ( the x shaped one works well) I have a hole in the centre of the pulley to give access to the servo arm screw
Regards. Ken
verithingeoff
« Reply #3 on: September 28, 2016, 12:24:19 am »
Hi Guys, thanks for the replies I just checked with the valve supplier and although the valve rotates through about 400 degrees it delivers full pressure at 90, so the solution is much simpler
« Reply #4 on: September 28, 2016, 05:39:35 am »
....ahah  :o......I think Geoff really wanted say.......
"Hi Guys, thanks for the replies I just checked with the valve supplier and although the valve rotates through about 400 degrees it delivers full pressure at 90, so the solution is much simpler"
Well a 400 degree rotary motion valve certainly must be unique in construction with some form of helical design to add the extra 40 degrees without being back to .dot +40 degrees from where you started from {-)
Is the valve hydraulically balanced internally?.......using steam to assist or overcome the movement of the valve against the boiler relief valve setting?
verithingeoff
« Reply #5 on: September 28, 2016, 05:57:52 am »
Hi Derek
I just had another look at the valve and it actually rotates more than 400, more like 585 . I don't know how it works, I'll ask the supplier
steamboat66
  • maybe it will float!
« Reply #6 on: September 28, 2016, 05:17:20 pm »
most steam valves are needle type. with a fine point and thread, they may have several turns to fully open. with a short point and thread, they may have less than one turn.
« Reply #7 on: September 29, 2016, 12:20:47 am »
I certainly am aware our boiler mounted steam isolation valves are usually needle valves with a conventional hand wheel, however we don't see too many which are servo operated apart from steam regulator valves which appear to be limited to -90 degrees movement and with internal physical stops
So hence my wonder of the design..............Derek
verithingeoff
« Reply #8 on: September 29, 2016, 12:29:54 am »
Here's the valve on question http://www.clevedonsteam.co.uk/products.html#Lever Valve.
« Reply #9 on: September 30, 2016, 10:47:28 pm »
Geoff....is this not the same boiler from another WEB site but with a different valve?........... Derek
verithingeoff
« Reply #10 on: October 01, 2016, 12:09:02 am »
Well spotted Derek :-))
This is how it finished up
Page created in 0.61 seconds with 18 queries.
