No need to remove anything, my man.
I think it was just one of those questions that easily throws the readers (us) off track.
Leastways, I don't think HS93 meant it to sound off'ish. But if I'm proved wrong, then go right ahead and do your stuff.
You're doing a fair job. Don't panic.
Bigfella:
Your enthusiasm is admirable. But where to start.
You obviously know the business end of a soldering iron, but where are you regarding basic electronics? Are you comfy/familiar with transistors, resistors, capacitors, etc?
If, as I suspect, that you're relatively new to this caper, then, as a suggestion, it might be best if you cut your teeth on a tried-and-tested kit first - as opposed to jumping in the deep end.
Again, this is where companies like AcTion-Electronics come to the rescue. Their kits are designed that Mr. Average constructor should have absolutely no problem with putting one together. All the hard work has already been taken care. That means that we - the end user - gets the joy and satisfaction of making something that we KNOW will work... first time, every time.
Still wanna build your own RC gear?
Good for you. All the help you'll ever need is right here, on this forum. But you'll be flogging a dead horse if, for instance, you're unsure of, say, the pin-outs of any particular transistor, or even basic Ohm's Law. Nope, I'm not trying to put you off -- just the opposite, in fact. There are some real smart electronic whizz-kids hanging out right here on Mayhem (and I mean REAL smart... unlike I).
But if you want to give electronics a whirl, then I'd wager it's a foregone conclusion they'll be only too happy to help you melt solder.
