Author Topic: E-Cigerette bases smoke machine  (Read 4713 times)
« on: October 23, 2016, 04:22:46 pm »
Battery powered fog machine (Indestructibles! ) - http://www.instructables.com/id/Battery-Powered-Fog-Machine/?ALLSTEPS
Re: E-Cigerette bases smoke machine
« Reply #1 on: October 23, 2016, 04:32:25 pm »
That is effective! It might be a bit large for some modesl but the technology is basically proven.
« Reply #2 on: October 27, 2016, 05:51:57 pm »
Umi_Ryuzuki
    • Models and Miniatures
« Reply #3 on: October 27, 2016, 08:33:11 pm »
Geoff
« Reply #4 on: November 11, 2016, 01:51:04 pm »
Interesting but is the issue with the lipo batteries rather than the smoke unit. Can you power a vaping unit with a regular 12 volt lead acid battery?
Geoff
« Reply #5 on: November 11, 2016, 02:00:27 pm »
Yes,  'volts' are 'volts'!
g6swj
  • Short Wave Jammer! -.-
« Reply #6 on: November 11, 2016, 03:10:43 pm »
I think these vape gizmos ( the big buggers) rely on very heavy current draw hence lipo which lead acid can not delivery
« Reply #7 on: November 11, 2016, 05:03:32 pm »
The vape devices are intended to be hand held, so the power source needs to be light, compact and capable of heavy current.  In a boat, an SLA will be perfectly adequate.
Umi_Ryuzuki
« Reply #8 on: November 22, 2016, 07:52:07 pm »
Explody issue solved... :-))
So how do these trigger, suction, or press a switch, and it fogs, and user inhales.
If it is switch based, then a small fan should suffice to run the vapor out the stacks.
Geoff
« Reply #9 on: November 24, 2016, 02:35:07 pm »
Watching with interest but I'm not sure it will work effectively as with e-cigarettes the vapour is sucked into the lungs which warms the vapour and then expelled in a great cloud along with about 1/2 litres of warm air. I suspect the heating effect of the lungs has a lot to do with the cloud that is expelled.
I hope to be proved wrong!
Geoff
« Reply #10 on: December 25, 2016, 07:35:17 pm »
Umi_Ryuzuki
« Reply #11 on: December 26, 2016, 05:48:00 am »
Hmmm, At that point, it might be that all you want to purchase is an atomizer and a tank.
Then build your plenum and fan and wire it into the boat.
Page created in 0.244 seconds with 18 queries.
