Author Topic: Which one will be full first water first?  (Read 6525 times)
« on: October 31, 2016, 05:32:23 pm »
Cornishman
Re: Which one will be full first water first?
« Reply #1 on: October 31, 2016, 05:39:12 pm »
4
Hellboy Paul
« Reply #2 on: October 31, 2016, 05:43:44 pm »
3
« Reply #3 on: October 31, 2016, 05:49:37 pm »
A 3 from me
mrlownotes
« Reply #4 on: October 31, 2016, 05:55:00 pm »
3 and 4 will both fill at the same time, I think.
Bintur Ellenbach
Danny
  • Gorleston Model Boat Club
    • Gorleston MBC
« Reply #5 on: October 31, 2016, 05:59:52 pm »
3 and 4 together unless flow is fast, then 3  %)
« Reply #6 on: October 31, 2016, 06:03:21 pm »
3 because it has to fill before the syphon effect starts to fill 4
« Reply #7 on: October 31, 2016, 06:07:39 pm »
I'll say 4 - as 3 fills the pressure will force water into 4
Jerry C
« Reply #8 on: October 31, 2016, 06:45:02 pm »
If dripping tap 3 and 4 together.
Jerry.
DavidHughes
« Reply #9 on: October 31, 2016, 06:45:49 pm »
Assuming the diameter of the tube between 2-3 is the same as 3-4 so that the flow rate into and out of 3 is roughly equivalent, and you mean full to the brim, then 3 and 4 will top out at the same time.
I knew paying atenshun at skool would pay off sooner or later
kinmel
« Reply #10 on: October 31, 2016, 06:46:20 pm »
Assuming the water enters 1 no faster than it enters 2,3 and 4,  then 3 and 4 will overflow together, 1 and 2 will never fill.
TheLongBuild
  • Build em, and play hard..
« Reply #11 on: October 31, 2016, 06:46:35 pm »
3 & 4 at the same time
Cornishman
« Reply #12 on: October 31, 2016, 07:42:04 pm »
3 and 4 at the same time because 3 and 4 are connected and they will act as one tank. The connecting pipe will never act as a syphon
Nemo
« Reply #13 on: October 31, 2016, 07:49:35 pm »
 {:-{ I would go for 3&4 at same time.
The consensus therefore is that the question cannot be answered correctly - unless there is a definitive answer?
TheLongBuild
« Reply #14 on: October 31, 2016, 08:10:38 pm »
who is going to build it then ?.
kinmel
« Reply #15 on: October 31, 2016, 08:20:29 pm »
If the rim of tank 3, or four is dirty, then that tank will overflow first. The dirt will collapse the surface tension
Nemo
« Reply #16 on: October 31, 2016, 09:52:44 pm »
It will be Long whoever it is! O0 and  %%
g6swj
  • Short Wave Jammer! -.-
« Reply #17 on: October 31, 2016, 10:13:18 pm »
« Reply #18 on: October 31, 2016, 10:21:16 pm »
3 will initial fill to the point that it overflows into 4 where when 4 reaches the same volume will equally fill until overflowing as 2 will only fill sufficiently to allow both 3 and 4 to overflow. simples
