Author Topic: Ball Bearings -  (Read 2828 times)
g6swj
  • Short Wave Jammer! -.-
Ball Bearings -
« on: November 11, 2016, 07:42:47 am »
Help!
I was rebuilding a control stick on a radio transmitter and need to get some ball bearings to replace those that are missing - ( ...long story but the aftermarth involved unsuccessfully crawling over the floor with a torch, a magnet and sticky tape)
Not sure exactly how to measure the little blighters as they are increibly small - > 1mm I think.
Can anybody point me in the direction of a supplier. I think all I can do is buy a few sizes starting at 1mm or so getting smaller and see which ones fit.
Thanks in advance for any pointers
Jonathan
Re: Ball Bearings -
« Reply #1 on: November 11, 2016, 09:03:05 am »
Make / model of Tx?    :-)
g6swj
Re: Ball Bearings -
« Reply #2 on: November 11, 2016, 09:38:09 am »
Hi Martin
TX Graupner MC32
New sticks are £80-120 and factory fit only!
I think my "missing balls" are 0.8mm so will see if I can locate a supplier.
Having just googled lots - I have found 100 for £70 but also realise that they may be the size of the balls in some Biro's so maybe there is a readily available source - just need to find some Latex gloves:)
Jonathan
david48
Re: Ball Bearings -
« Reply #3 on: November 11, 2016, 02:07:36 pm »
try Simply Bearings www.SimplyBearings.co.uk
I have had loose steel balls from this company.
David
g6swj
Re: Ball Bearings -
« Reply #4 on: November 11, 2016, 02:24:45 pm »
David,
Thank you for the link - I had found this company on the net = 10 x 0.8mm ball bearings £12 - that's £1.20 each for something about the size of a grain of salt:) but certainly cheaper than a replacement module.
I may resort to this option - for now I am intending to carry out "open heart surgery" on 20 Bic Biro's. Also wondering what else I have in my den (old CD player etc ) that may have some of these little guys hiding in...
Also scheming to use the hoover with an old pillow case or similar across the suction end and see if I can find the absentees
Jonathan
Chris57
  • Fishers Green mbc
Re: Ball Bearings -
« Reply #5 on: November 12, 2016, 05:08:49 pm »
Hi, I was at Warwick yesterday, and saw packets of ball bearings for sale on Tony Green Steam models stall. I only remember they went down to minute, (smaller than 1 mm) . BUT, they may only be available in imperial sizes? As per a lot of steam fittings?
Www.tonygreensteammodels.co.uk   - no connection, just a suggestion.
Chris B
g6swj
Re: Ball Bearings -
« Reply #6 on: November 13, 2016, 03:54:04 pm »
Chris,
Thank you for the info - I had a look today the smallest they had where 1/16th I think 0.8mm is more in the direction of 1/32nd
Jonathan
g6swj
Re: Ball Bearings -
« Reply #7 on: November 13, 2016, 07:45:51 pm »
20 Bic doners......
Just need a bath in some solvent to remove ink
g6swj
Re: Ball Bearings -
« Reply #8 on: November 15, 2016, 12:14:50 pm »
They cleaned up really well - just got to fit them now!
To give an idea of scale this is them sitting on the rim of a 1p coin
Jonathan
