Author Topic: semi scale pre dreadnought Andre  (Read 6240 times)
petesubman
« on: November 23, 2016, 01:19:02 pm »
This is the next semi scale flat botom build based on the Radiguet tinplate dreadnought  Andre, the Borodino build has taught me so much about this type of model, i have two pictures to work from , her length is 47 inches beam 15 inches at the centre of the hull as per the original which was powered by a petrol engine , my version will use a steam plant, this model has been about a year on and off ,and with borodino virtually complete  , i have some spare time.
A pic of the hull frames stood and screwed temporarily,  boiler and engine, rear frames and false deck and one of four large
gun mounts attached to the outer hull, regzrds Pete
petesubman
Re: semi scale pre dreadnought Andre
« Reply #1 on: November 23, 2016, 01:24:23 pm »
Here is a pic of her, think she was sold as part of the forbes collection, Pete
timg
« Reply #2 on: November 23, 2016, 08:17:05 pm »
Wow Pete
That will look very menacing on the pond
Good luck with the build
Spud
petesubman
« Reply #3 on: November 24, 2016, 02:55:31 pm »
Thanks Spud,  im going to plank the upper hull from the  water line, dont think this will be a  quick build , regards Pete
« Reply #4 on: November 24, 2016, 09:48:07 pm »
Oh good, another Ninteenth century behemoth build to folllow over the winter months. Your framework and sponson looks good Pete.
petesubman
« Reply #5 on: November 25, 2016, 05:49:12 pm »
Thanks Ian, it may be better than some of the tv , still not sure how proceed with cladding the hull,  from the hull bottom to the waterline is 90mm birch light ply strip, so its either planking or card, will have to experiment, regards Pete
petesubman
« Reply #6 on: December 02, 2016, 03:11:29 pm »
A little more work done on the Andre , hull waterline strip in place, forward sponson upper in the correct position, have decided to plank the upper hull instead of card. The card looked to angular, regards Pete
« Reply #7 on: December 02, 2016, 06:19:01 pm »
I see how you are doing the ends now. Rebating the ends of the planks will save you hours of fun.
petesubman
« Reply #8 on: December 21, 2016, 03:23:20 pm »
Had a change of mind and decided to clad the hull in card board , thats as far as i go till after christmas, also put a mikasa bare hull together with the ply sheet i had left over , couple of pics of the hull clcdding so far, regards Pete
« Reply #9 on: December 27, 2016, 06:48:32 pm »
I salute you Pete for the sheer volume of shipping you are building! I cannot get my head around the fact the hull is not upside down, the tumblehome is so extreme! Looking forward to seeing her and a few sisters in 2017.
« Reply #10 on: December 27, 2016, 10:07:03 pm »
A Google search on Borodino Class reveals a few images ......
A full section of what appears to be her shell/projectile for her '6 × 2 - 6 inches' (152 mm) gunshandling system.... [assumed six sets of twin 6" mounts]
Must admit, I had never seen such hull design in a relatively modern build.......Derek
______________________________________________________________
Courtesy WIKI.....
Builders: Baltic Works, Saint Petersburg
New Admiralty Shipyard, Saint Petersburg
Operators:  Imperial Russian Navy
 Imperial Japanese Navy
Preceded by: Tsesarevich
Succeeded by: Evstafi class
Built: 1899–1905
In service: 1904–1922
In commission: 1904–1922
raflaunches
  • The Penguins are coming!!!
« Reply #11 on: December 27, 2016, 10:17:32 pm »
Wouldn't say it was modern!- It was all the standard for Russian and French warships about 110-115 years ago! Good sea boats terrible as warships- too much area to armour, British warships of the time sat lower in water which helped with protection from plunging side glances from shells.
Nick B
Illegitimi non carborundum!
Geoff
« Reply #12 on: December 29, 2016, 02:02:29 pm »
Tumblehome was actually primarily a weight saving method. The actual deck area was reduced. The concept was such ships with high free-board would be seaworthy. The waterline was protected with a shallow very thick belt with a protected deck above it. Turrets and the like sat on armoured tubes. In practice it didn't work too well as ships were invariably heavier than designed so the belt was more immersed so the lightly protected side was very much prone to flooding and the free water effect would cause a capsize. The tumblehome was also to produce a stronger hull. Think of an egg and how strong the shell is to crush damage. British ships of the same period did not have a significant amount of tumblehome albeit some for hull strength. They also had thinner armour over a larger area to protect the waterplane. Tuishima speaks for itself!  Cheers Geoff
Klunk
« Reply #13 on: December 29, 2016, 02:41:37 pm »
Isnt this the ship that wss in monoplly sets????
full time penguin
petesubman
« Reply #14 on: December 29, 2016, 02:52:24 pm »
Thats right klunk , i call borodino the ss monopoly when shes on the water, regards Pete
tghsmith
« Reply #15 on: December 29, 2016, 03:07:58 pm »
this was a time of tech advancing faster than construction, ship were often nearly obsolete when launched,, Tuishima was a real world test of methods, the armour didn't fail the bolts holding it in place did..one German battleship was up-armoured and up-gunned during construction so much that she had so little free board at launching.. many of these ships may have had longer lives but this was also the period of change from piston steam plants to turbine, from coal to oil fired..The US navy used tumble home in many of their crusiers and flat iron hulls in battleships, not saying they new what was best, they still built a ram.. tumble home is back on the most advanced warships, but now for a new reason,, radar stealth..
timg
« Reply #16 on: December 31, 2016, 10:00:32 pm »
Hi Pete,
The hull is covering quickly,  will you be lining the inside to protect it from the heat?
What colour will the hull above the water line ?
Spud
petesubman
« Reply #17 on: January 01, 2017, 02:27:51 pm »
Hi Spud , will resin inside the hull ,ive hung on to some biscuit tins to make up the inner heat shield , as for the paint scheme i was looking at a dark battleship grey or the anthracite and buff  colour scheme, regards Pete
« Reply #18 on: January 01, 2017, 06:57:02 pm »
Hooray for Christmas and the biccy tins:O) Either colour scheme will look good though the Ninteenth century spit and polish would look more impressive.
Page created in 0.332 seconds with 18 queries.
