Author Topic: If not F14, then what?  (Read 3774 times)
adamD98
  • Born free, forced to work!
« on: November 29, 2016, 11:47:58 am »
Hi all,
 I'm currently on with a new build which will be 1 of 2 needing a minimum of 8 channels and I'm very unsure of what my best options are. So, I guess this is where you come in if possible, and just to point out, the least difficult to understand, the better  %)
A quick breakdown of the uses for these channels;
Tank steering for 2 shafts, 2 fwd and 1 aft thruster, rudders, towing winch, anchor handling winch, radar, lights...and possibly some extras depending on how the build goes.
 Thanks in advance folks  :-))
Cheers,
-Adam-
g6swj
  • Short Wave Jammer! -.-
Re: If not F14, then what?
« Reply #1 on: November 29, 2016, 12:16:10 pm »
Hi Adam,
Do you currently have an F14?
How many of the channels need to be porportional control vs. switched? Something like the list below
1 - Shaft/Motor 1 Proportional
2 - Shaft/Motor 2 Proportional
3 - Thruster Forward 1 - prop or switched?
4 - Thruster Forward 2 - prop or switched?
5 - Thruster Aft 1 - prop or switched?
6 - Towing winch - switched? e.g. retrieve / off / release ( with safety stops)
7 - Anchor switched? e.g. - up / off / down  ( with safety stops)
8 - Radar - switched on/off
9 - Lights - on/off
Jonathan
HMS Invisible
  • MICROGYROS.COM
    • Yes, it works!
« Reply #2 on: November 29, 2016, 01:50:49 pm »
Hi Adam,
Do you have dinner-plate size hands needed to work an F14?
Somebody has suggested 4 channel 433 MHz modules from Ebay for switched functions before. Add diodes and micro switches and you have taken care of winch mechanisms.
The price for a four function 433Mhz switcher is £15 (or £7.50 + 1 month airmail delay from China)
Crossie
« Reply #3 on: November 29, 2016, 06:33:42 pm »
 Maybe a Carson radio set like the model truck fraternity use would do what you want Adam? They are cheaper than a F14 and the extra decoder that is required, the Carson Rx has , I think, 14 servo/switch outlets.
               Trevor
« Reply #4 on: November 29, 2016, 07:21:20 pm »
Would an ACTion module not be able to handle proportional simulated twin motor tank steering and twin rudders on one channel?
tsenecal
« Reply #5 on: November 29, 2016, 08:27:39 pm »
since this is for a boat, and not a sub... why not try an FrSky Taranis?  the x9d model is roughly $200, and you have several ways of configuring it to use up to 32 servos or devices that operate like servos, if you have 2 receivers and mixing involved.  mixing on the Taranis is incredibly simple.  tank steering for my tugboats took about 15 seconds to set up.  adding a bow or stern thruster to that mix would take another 15 seconds.
http://www.frsky-rc.com/product/pro.php?pro_id=137
if you have any questions about the general arrangement of the radio, i own one and would be happy to answer your questions.
rob
« Reply #6 on: March 20, 2017, 02:51:08 pm »
Great news for F14 fanciers ( I am one )
I've just spent a couple of hours with a very nice man, in fact the Ripmax rep.
He tells me that the F14 is available again,complete with all the switches knobs and linear sliders and even the decoders, and is in the Ripmax catalogue.
Not only on 40 meg, but on 2.4 as well ( at slightly higher cost)
in my own little world
cos918
« Reply #7 on: March 20, 2017, 09:20:57 pm »
Look at modern radios. If you want a lot then look at the frsky tranus x9e or x9d . for less money the carson reflex stick multie pro 14 ch
john
Bob K
  • Bob K
« Reply #8 on: March 20, 2017, 10:25:49 pm »
For anyone with a submarine, or a low freeboard semi-submersible, 40MHz is essential.
Glad that you can get F14's again, including the various modules and parts.
All my other boats are on 2.4   Planet T5 & T7
