Author Topic: Wheelhouse Corners (scratch build)  (Read 6258 times)
tizdaz
  • Boom!
    • My RC TID Build
« on: December 02, 2016, 12:26:45 am »
Hi guys :)
what is best method for doing rounded corners on a wheel house (see pic below) I'm using 1.5mm ply for the structure, but I'm not sure what to use for the corners to give a curve effect, I'm thinking balsa or maybe a harder type of wood for added strength?
The bottom part of wheelhouse has a large radius & the top only has small radius..
cheers :)
My large-scale TID Build Website:
http://www.tizdaz.co.uk
Facebook:
tizdaz
  • Boom!
    • My RC TID Build
Re: Wheelhouse Corners (scratch build)
« Reply #1 on: December 02, 2016, 12:42:02 am »
What is this shape called below!?
As I'm thinking of using strips of wood in this shape for the corners but got no idea what the shape is called, i thought it was quadrant but when i search for quadrant strips of wood i'm finding nothing?
Facebook:
BrianB6
« Reply #2 on: December 02, 2016, 04:32:36 am »
Try 'quad'
furball
« Reply #3 on: December 02, 2016, 06:50:54 am »
Depending on the actual radius of the corner, you could use block for a very small radius, and for larger ones, either use vertical narrow planks or laminate a couple of layers of thin ply (1/32" or so) around the bend.
Lance
barriew
« Reply #4 on: December 02, 2016, 07:08:34 am »
Depending on the radius you can find this in any DIY store in the mouldings bin in the timber section.
Barrie
« Reply #5 on: December 02, 2016, 10:32:02 am »
As it is a tapered shape, I would tend to use some sandpaper on an ordinary square piece.
Hope this helps
« Reply #6 on: December 02, 2016, 12:08:02 pm »
It is called quarter round moulding/trim
grendel
« Reply #7 on: December 02, 2016, 01:39:47 pm »
or quadrant beading
« Reply #8 on: December 02, 2016, 02:54:36 pm »
B&Q call it quadrant moulding
Measured flat/flat/length.
John W E
  • I see no ships !!
« Reply #9 on: December 02, 2016, 05:04:30 pm »
hi there
 depending on the radius - on the corners - use a square section timber glued at the edge of the cabin wall - then sand it to the radius desired - couple of pics of the Cervia tug build from the masterclass thread to explain on here
john
Knowledge begins with respect
Fastfaz
« Reply #10 on: December 02, 2016, 07:11:09 pm »
   Yo Daz,
        I am really busy  over the weekend but if you PM me with your email address I will give you some tips as to how to do the (sounds odd!) round corners without throwing bits around in frustration. Hope this helps through the stress.
     Cheers,
            Pete.
tizdaz
  • Boom!
    • My RC TID Build
« Reply #11 on: December 02, 2016, 09:23:21 pm »
Cheers for info guys! ...sent you a PM Pete :)
Facebook:
