Author Topic: Aeronaut Queen  (Read 6897 times)
KOI
Aeronaut Queen
« on: January 04, 2017, 08:03:25 am »
I am building an aeronaut Queen and am curious about motor, battery and ESC.
In the spec, it says a 8.4V 3800 battery, speed 600 7.2v motor and 25amp esc. The prop is 40mm 3 blade.
What I cant understand is two things-
Would it be right that they suggest brushed motor as opposed to brushless when costs are not that different.
I also cant see what RPM would be needed to get the boat to plane
Any help or guidance on this would be much appreciated
Re: Aeronaut Queen
« Reply #1 on: January 04, 2017, 09:55:16 am »
Hi Koi,
Unfortunately, this is still a tricky / grey area / experimental subject. {:-{
Very few boat kits come with specified Brushless option, which is disappointing seeing brushless technology has been around for quite some time now. Mind you, some modellers don't like the 'whine' that some brushless motors produce.....  {:-{
A good place to start is this great topic by AndrewH  :-))
http://www.modelboatmayhem.co.uk/forum/index.php/topic,13538.msg130068.html#msg130068
( seems I need to re-embed the photos!  )  :((
Also see:
http://www.modelboatmayhem.co.uk/forum/index.php/topic,42219.0.html
http://www.modelboatmayhem.co.uk/forum/index.php/topic,25309.msg248599.html#msg248599
http://www.modell-schiffbau.de/yachten-speed-funboote-bauberichte-f27/queen-von-aeronaut-t652.html
https://www.rcgroups.com/forums/showthread.php?1286343-Brushless-motors-for-boats
https://youtu.be/GNI4snZceU8
Re: Aeronaut Queen
« Reply #2 on: January 04, 2017, 10:58:44 am »
Additional:
I've got the HobbyKing Aquaholic race boat, which roughly the same size ( but I'm guessing, considerably lighter! ), that comes fitted with a:
BL2815 Brushless Outrunner Motor For Quanum Aquaholic / Relentless Racing Boats.
Specs:
Kv (rpm/v): 1900
Weight: 132g
Max Voltage: 11.1V
Shaft Diameter: 5mm
Stator Dimensions: 28 x 15mm
Motor Length: 38mm
Motor Width: 39mm
Extended Shaft Length: 20mm
https://hobbyking.com/en_us/bl2815-brushless-outrunner-motor-for-quanum-aquaholic-relentless-racing-boats.html
sparkey
Re: Aeronaut Queen
« Reply #3 on: January 04, 2017, 04:44:54 pm »
In mine I have a prop-drive 42-58 500kv outrunner from hobbyking with 80amp ESC running on 14.8v 4c 5000mah lipo,goes like stink and with an outrunner no need for water cooling for motor.
Re: Aeronaut Queen
« Reply #4 on: January 04, 2017, 06:30:30 pm »
What prop you spinning on that Sparky?
Re: Aeronaut Queen
« Reply #5 on: January 04, 2017, 09:28:28 pm »
Rpm at that voltage would be 15500
http://calbugs.com/http___homepage.ntlworld.com_edward.matthews_ddmbc_files_motors_graupner.pdf
KOI
Re: Aeronaut Queen
« Reply #6 on: January 05, 2017, 07:40:41 am »
Hi all, thanks for coming back, will have a look today at esc, motor and battery to go brushless. As I don't have any spare kit at the moment, will be a fresh set up so will probably go brushless. Any suggestions where to purchase for a good deal would be helpful.
Re: Aeronaut Queen
« Reply #7 on: January 05, 2017, 07:46:56 am »
Component shop do a good range of brushless motors and esc
sparkey
Re: Aeronaut Queen
« Reply #8 on: January 05, 2017, 08:17:11 am »
Martin,I have a 50mm 3 blade brass.
sparkey
Re: Aeronaut Queen
« Reply #9 on: January 05, 2017, 08:25:28 am »
 :-)) Forgot to add,I got this set up from the guys who done the model boat trip down the Thames,forgot their names,it has been used by a lot of other guys as well and I have the same in my princess as well,so it is well tried and tested.
KOI
Re: Aeronaut Queen
« Reply #10 on: January 05, 2017, 11:02:03 am »
Hi Sparkey, thanks again, will definitely look at going along the same lines
Thornej
  • Newbie (for now!)
  • Model Boat Mayhem is Awesome!
Re: Aeronaut Queen
« Reply #11 on: October 14, 2017, 12:05:22 pm »
Hi Sparky,
Greetings from downunder!
Thank you for the motor information.
What runtime do you get on the battery?
Jeff
Page created in 0.282 seconds with 18 queries.
