Author Topic: PBR  (Read 3335 times)
david5
PBR
« on: June 05, 2017, 07:11:08 pm »
A clubmate would like to build a 1/6 scale Pibber (as weapons and crew are available from 21st century),Christian in Gibraltar can do the hull but would need to do a minimum of four to be viable,about £95 plus p&p,water jets are available, anyone interested ?
David5
MadMax
Re: Pbr
« Reply #1 on: June 05, 2017, 08:37:57 pm »
forgive my ignorance ...how big is 1/6 scale in inches please
Re: PBR
« Reply #2 on: June 05, 2017, 08:46:27 pm »
david5
Re: PBR
« Reply #3 on: June 05, 2017, 09:03:44 pm »
62" long for a mark 1
David5
mrlownotes
Re: PBR
« Reply #4 on: June 05, 2017, 10:36:39 pm »
My maths may be suspect, however I estimate the displacement of a PBR at 1/6th scale to have a sailing weight (displacement) of approx 128kg.
If I'm right you will need a lot of lead and some good friends (strong ones) to help put it in the water.
Bintur Ellenbach
longshanks
Re: PBR
« Reply #5 on: June 06, 2017, 08:00:18 am »
I reckon 42Kgs would be closer to the mark...........
Which does raise the question of power and supply to get this mass on the plane and keep it there
longshanks
mrlownotes
Re: PBR
« Reply #6 on: June 06, 2017, 08:47:25 am »
longshanks
I was going by a 1/24th scale PBR displacing 2kg, then factoring up from there.
Bintur Ellenbach
Re: PBR
« Reply #7 on: June 08, 2017, 08:56:08 am »
Either it wasn't 1/24 or it wasn't a PBR or it sits with the water lapping the deck.  A 32ft by 2ft by 10ft block at 1/24 is about 2 and a bit kilos, a PBR is not a block underwater.
For big beastie power maybe one or two of these? - https://www.banggood.com/Mini-49cc-Two-Stroke-Air-Cooled-Racing-Engine-Manual-For-Motorcycle-Quad-Dirt-Dirtbike-p-986735.html?rmmds=category
mrlownotes
Re: PBR
« Reply #8 on: June 08, 2017, 09:17:12 am »
I concur..........working from the top down with a Mark2 PBR at 32feet and displacement 8.9 tons.... At 1/6 scale we end up with 42kg. I'll crawl back into my shell now, suitably embarassed.
Bintur Ellenbach
