Author Topic: HMS Magnificent  (Read 9643 times)
6705russell
HMS Magnificent
« on: September 04, 2007, 05:55:58 pm »
Dear all,
I am in the process of sorting out the props for my Deans Magnificent, it is twin prop and i am confused as to whether the props are supposed to turn inwards or outwards looking from the rear?
Can anyone help :-\
Russ
Re: HMS Magnificent
« Reply #1 on: September 04, 2007, 06:18:38 pm »
If you type "props" in the search box under your name you will get more information than you can handle. O0
Re: HMS Magnificent
« Reply #2 on: September 04, 2007, 06:24:09 pm »
 6705russell
If she has a single rudder inwards will improve steering response.
Twin rudders doesnt matter much.
6705russell
Re: HMS Magnificent
« Reply #3 on: September 04, 2007, 06:31:22 pm »
Thanks Guys O0
Bryan Young
Re: HMS Magnificent
« Reply #4 on: September 04, 2007, 07:22:35 pm »
Dear all,
Can anyone help :-\
Russ
Notwithstanding anything else that has been posted on this forum...and there have been LOTS I still maintain that outward turning props when viewed from the stern is the better all-round answer. Anyway, if you don't like it you can just try swapping the props around and change the rotation of the motors! Try both. BY.
Notes from a simple seaman
victorian
Re: HMS Magnificent
« Reply #5 on: September 05, 2007, 11:18:58 am »
The props on my Hannibal based 'Mars' turn inwards when ahead, ie port clockwise, stbd anticlockwise. I found differential steering essential for safe handling near the shore. Power is two car heater motors. This is a heavy model and you need to be sure it won't run away on radio failure, as mine did!
If you are building 'Magnificent' note that the bridge structure is incorrect representing the mainmast aft of the bridge, not through it as it should be. Only the last three ships 'Prince George', 'Ceasar' and 'Hannibal' had the layout shown in the kit. Only 'Mars' had the main deck torpedo net shelf as built - the net shelf ran along the upper deck in the other ships and is much narrower than depicted in the kit.
Watch out for the printed bridge structure in the kit which is out of proportion and needs to be done again. The masts on the ships as built were mostly stepped not as shown in the kit. And numerous other details!
I'm not criticsing Deans over this - the hull is excellent and my model would never have got built without it. Congratulations to them for producing such an unusal prototype, long lost now and surprising to many spectators who've never seen the Victorian colour sheme.
rp6705
Re: HMS Magnificent
« Reply #6 on: September 05, 2007, 12:10:22 pm »
Thanks again Victorian, can yo tell me what weight of ballast you nedde to get it down to its waterline?
Many thanks
Russ
victorian
Re: HMS Magnificent
« Reply #7 on: September 05, 2007, 12:32:30 pm »
Total weight from memory is about 50lbs. I use 2 12v 12AH gel cells (about 15lbs each) as removable ballast. This gives a light water line, as though the coal is mostly gone. A further 8v 6AH gel cell (about 5lbs?) loads it to the white line and looks better if it's not too rough. I've never shipped any water but the superstructure design doesn't have any coaming so it could be vulnerable.
One of these batteries gives a seemingly unlimited sailing time.
One thing to watch out for with these heavy batteries is that if not restrained they will move if you hit something. That's what happened when it ran away and the stern was close to going under. I reinforced bow and stern with heavy filler and I'm glad I did!
I got my granson to work out the displacement in the bath and we got 18,000 tons, not far out, so he could tell his teacher that he weighed a battleship in the bath!
rp6705
Re: HMS Magnificent
« Reply #8 on: September 05, 2007, 01:46:50 pm »
Are your bigger batteries located in the centre?
Did you need any ballast at the front of the ship?
Russ
Bryan Young
Re: HMS Magnificent
« Reply #9 on: September 05, 2007, 06:07:14 pm »
This one looks superb. Looks good enough to be one of Brian Kings! (And that is PRAISE!).
Re: HMS Magnificent
« Reply #10 on: September 05, 2007, 06:35:04 pm »
Weird posting Bryan  ???
victorian
Re: HMS Magnificent
« Reply #11 on: September 05, 2007, 07:41:37 pm »
Here's a shot of the loading. All the ballast is at the centre so that it can all be removed for carrying the model.
Bryan Young
Re: HMS Magnificent
« Reply #12 on: September 05, 2007, 09:12:36 pm »
Answered the wrong line is all..did't scroll down far enough. Sorry!
victorian
Re: HMS Magnificent
« Reply #13 on: September 05, 2007, 10:14:37 pm »
Thanks for the compliment Bryan but my model is nowhere near the quality of Brian King's work I'm afraid.
My recollection of the weights was way off. The total ballast (according to our bathroom scales!) is 11.5 Kg, or 8.6 Kg when lightly loaded with the two 12AH batteries. An estimate for the total displacement is about 17 Kg, closer to 37.5 lbs than the 50 lbs I mentioned. Scaled up, that's 14,800 tons which agrees remarkably with the 14,820 tons quoted by RA Birt in Conway.
Admhawk
Re: HMS Magnificent
« Reply #14 on: September 05, 2007, 10:23:31 pm »
Russ, I'm piping in a bit late, but are you wanting to know which way the original ship was, or what is best for your model?
rp6705
Re: HMS Magnificent
« Reply #15 on: September 06, 2007, 06:55:12 am »
I wanted to know which was best for the model, i have them turning inwards looking from the back?
I will see how it performs on the water this weekend.
Russ
Re: HMS Magnificent
« Reply #16 on: September 06, 2007, 09:01:59 am »
Russ
Run my Scheutze turning in, definitely helps the steering.
J.beazley
  • The building never ends
Re: HMS Magnificent
« Reply #17 on: September 06, 2007, 01:29:56 pm »
Same here Richard got mine running inboard much better steering.
remember INBOARD=better steering OUTBOARD=better speed (or something like that)
Jay
Ghost in the shell
Re: HMS Magnificent
« Reply #18 on: September 09, 2007, 04:02:48 pm »
i'd never thaught it would make any difference which way the props turned, anyone willing to do some scientific testing?
Go Nuclear!  you'll love it
Bryan Young
Re: HMS Magnificent
« Reply #19 on: September 12, 2007, 06:40:56 pm »
Try driving a "full size" ship and you will rapidly appreciate the difference!
Page created in 0.195 seconds with 19 queries.
