Author Topic: 1/12th Speedline Severn railings  (Read 3574 times)
RMH
« on: November 29, 2017, 07:23:06 pm »
Hi All
I have reached the stage of making the railings for my Severn. For the bow railings I used 3.3mm rod that came with the kit but I don't think there is sufficient to do all the railings, along with the 3.3mm rod came half a dozen long lengths of 2.7mm rod. So my question to others who have built the kit is which did you use and where or will I have to try and find some more 3.3mm rod?
Richie
T33cno
Re: 1/12th Speedline Severn railings
« Reply #1 on: November 29, 2017, 07:48:45 pm »
No personal experience but I think generally the thicker rod is for the top rail and the thinner rod for the lower rails?
RMH
« Reply #2 on: November 29, 2017, 08:22:22 pm »
Looking at photo's of the real thing each of the railing sections appear to be made of the same thickness material.
T33cno
« Reply #3 on: November 29, 2017, 08:28:47 pm »
If the rod came with the kit and you ran out it would suggest to me that you used the wrong rod for the wrong purpose?
T33cno
« Reply #4 on: November 29, 2017, 08:36:44 pm »
I imagine the best source of the same size rod is Speedline
« Reply #5 on: November 29, 2017, 09:09:36 pm »
I think if you google k&s brass, you'll find what you want.....1/8th " = 3.3mm and you can buy it in 300mm or 1000mm lengths
think that's where Adrian told me he got his lengths from....the same supplier as k&s.
https://www.google.co.uk/search?source=hp&ei=ayAfWun-II2XsAep07PYAQ&q=k%26s+brass+rod+sizes&oq=k+%26+s+brass&gs_l=psy-ab.1.5.0l2j0i22i30k1l8.3936.16384.0.19979.11.10.0.1.1.0.88.807.10.10.0....0...1c.1.64.psy-ab..0.11.851...0i131k1j0i22i10i30k1.0.sfdNhBGUdM0
lesfac
  • Never too late for a happy childhood
« Reply #6 on: December 12, 2017, 12:40:13 pm »
I only got 12 gauge rod with my kit and like you I am running out. Having used most of the 12 gauge (2.65 mm). I had a look for more 12 gauge brass and failed to find any. I will have another try to source some shortly. I thought the size had to be correct because it came with the kit. If anyone can suggest a source I would be grateful.
Les
RMH
« Reply #7 on: December 12, 2017, 05:11:13 pm »
Hi Les
Thanks for your reply. I am now going to use the 2.7mm rod to do the rest of the railings. The standard mounting bosses have 2.7mm holes so it makes sense to use that size but I still can't work out why I have all that 3.3mm rod
Richie
Page created in 0.388 seconds with 18 queries.
