Pages: [1] 2 3 4 5   Go Down
Author Topic: IJN Akizuki 1:100 scale build  (Read 35075 times)
T888
« on: January 02, 2018, 05:25:38 pm »
Hi Gents,
First I would like to wish All MBM Happy New Year.
This is my new project,  which if there's interest I will do a build log. The model will be a fully scratch build of a WWII Akizuki Class Destroyer at 1:100 scale.
I'm using Kagero 3D book and 1:200 scale drawing which I've scaled up to 1:100, as my basis for the model.
The hull is made from 3mm ply frames, 2mm Balsawood skin which I've painted with resin. The deck is made from 2mm ply and will have diamond plate plaster card covering.
I've attached photos to show progress so far.
Regards David
Re: IJN Akizuki 1:100 scale build
« Reply #1 on: January 02, 2018, 09:33:44 pm »
More please Mr 888. This looks to be an interesting build. The sheer on that bow is going to insure your bow is dry in all but a rain storm  :-))
Umi_Ryuzuki
    • Models and Miniatures
« Reply #2 on: January 03, 2018, 01:04:56 am »
Great work, :-))
A friend in Japan sent me plans from Miyuki Kai, for the Naganami, and Yugumo, and the Kagero.
We have framed up two hulls for the Kagero class in 1/72nd scale, And I have started on some details.
Wish we could share parts...
T888
« Reply #3 on: January 03, 2018, 04:16:59 pm »
Umi_Ryuzuki
Thanks for the feed back, yes it's a shame we're not building to the same scale, would have been nice to share fittings.
I plan to use the torpedo tube as a master for moulding once I've added some more details , as with the range finder and doors will also be used as masters.
I do like your fittings , they look very detailed, clean and sharp.
Ian, like you the bow flare was one of the things I liked about the ship and which drove me to start making this model
Regards David
« Reply #4 on: January 03, 2018, 10:56:39 pm »
I am looking forward to see your progress T888!
Excellent fittings Umi  :-))
T888
« Reply #5 on: January 05, 2018, 02:46:11 pm »
Made the rudder last night,
My Usual methods is to use a photo copy of the rudder from the drawing as a temple , then transfused this to 4 x 2mm plastic card, which I laminated, after sanding to shape I use tippex as a filler, then use 150 grit to sand to a fine finish.
Regards David
« Reply #6 on: January 05, 2018, 09:43:35 pm »
Tippex used as filler? Interesting. I have heard of model engineers using it whilst silver soldering to mask areas they don't want soldering.
Do you have to be more careful whe sanding it?
T888
« Reply #7 on: January 06, 2018, 07:21:23 am »
Hi Ian,
I picked the Tippex tip up years ago when  making Airfix kits, where parts did not fit well. Plastic modlers used it as a joint filler. I find It flows in to joints and scratches filing them up well.
I let it dry over night before sanding, once the part is painted , I've never had any issue with it flaking off or being affected by water.
Regards David
« Reply #8 on: January 06, 2018, 01:07:15 pm »
I can understand the water resistance as it is solvent based (or was) so this may also help with adhesion on the plastics that share the solvent perhaps as their 'plasticiser'.
This gets more and more interesting  :-))
T888
« Reply #9 on: January 14, 2018, 04:57:30 pm »
Over the last few weeks I've been getting the hull ready for detailing and painting, however I've build the transom deck with some fittings which I'll make moulds later.
Regards David
« Reply #10 on: January 14, 2018, 05:11:34 pm »
The cylinders are depth charges I presume? The end detail is neat.
T888
« Reply #11 on: January 14, 2018, 05:39:33 pm »
Hi, Ian,
Yes they are depth charges.
Regards David
« Reply #12 on: April 02, 2018, 01:36:24 pm »
How are you getting on? I appreciate that real life gets in the way of our passions. I just thought I would check in  :-)
T888
« Reply #13 on: April 02, 2018, 02:33:57 pm »
Hi Ian,
Funny you should ask, I've been thinking about updating this build.
But with supporting the wife in her hobby ! Show dogs, going to Crufts, being asked to come out of retirement to be a trainner, so now I'm working two to three days a week. I've not had much time for this build.
However I've been doing some model work making the master fittings for my Shannon lifeboat , so not been going on with the Akizuki.
Attached are photos of progress to date.
Regards David
Stan
« Reply #14 on: April 02, 2018, 02:46:18 pm »
HI T888 this would  go well with your build sadly wrong navy.
Stan.
unbuiltnautilus
« Reply #15 on: April 02, 2018, 02:48:35 pm »
Akizuki is a graceful looking design. Most WW2 era Japanese destroyers could best be described as 'functional' in appearance, not this one. I could go for one of these at 1/72 scale!!
T888
« Reply #16 on: April 02, 2018, 03:02:17 pm »
Stan, nice model, just prime to be sunk by IJN  {-)
Alan, it would be a big model ! But at 1:100 it still would look good attacking PMBDT convoy  <*<
Regards David
« Reply #17 on: April 02, 2018, 03:24:23 pm »
Think of the Brownie points you are earning assisting your wife! She does look good, and definitely has a crafted look rather than a wartime emergency sort of look.
Keep up the good work when you have the chance  :-))
Stan
« Reply #18 on: April 02, 2018, 04:10:01 pm »
HI T888 Not sure if you know the carrier was sunk by the IJN. I think the IJN ship Tone had something to do with it.
Stan. :(( :(( :(( :(( :((
unbuiltnautilus
« Reply #19 on: April 02, 2018, 05:14:06 pm »
Size IS everthing %)
T888
« Reply #20 on: April 02, 2018, 07:15:46 pm »
Hi Stan,
Yes I did, if I'm correct ? she was the only U.S escort carrier to be sunk by surface warship gun fire ? During the Battle off Samar.
She still a nice model that you have made.
Regards David
T888
« Reply #21 on: April 06, 2018, 06:37:24 pm »
Hi Gents,
Just started to make the Funnel.
Regards David
« Reply #22 on: April 06, 2018, 07:55:47 pm »
I wish they made their funnel systems more complicated! I am interested to see how you flesh out the funnel system.
T888
« Reply #23 on: April 06, 2018, 08:32:11 pm »
This funnel has more curves than spaghetti junction ,I don't think the designer knew what a straight line was. This funnel will require a lot of sanding & filling.
Regards David
« Reply #24 on: April 07, 2018, 03:18:38 pm »
Don't worry, it will look good in the end especially with all the detail gubbins on it.
Pages: [1] 2 3 4 5   Go Up
