Pages: 1 2 3 4 5 6 7 [8] 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 ... 61   Go Down
Author Topic: What have you bought this week?  (Read 330163 times)
Re: What have you bought this week?
« Reply #175 on: February 07, 2019, 06:12:13 pm »
A 2 channel radio is all you needed for the DF.
What was the original radio?
Dave_S.
  • Member of Oxford Model Boat Club
« Reply #176 on: February 07, 2019, 06:30:26 pm »
A Planet 2+2 I bought for my scale boats, but it wasn't giving me enough throw on the winch, and I had no means of adjusting it. Got the new radio set to give me the 115mm travel with end points set to 110%
I've come from an aeromodelling background, where computer radios have been the norm for quite a few years now, but they never used to be anything like as cheap as the FlySky!
Ruining perfectly good kits since 1969.
« Reply #177 on: February 09, 2019, 02:33:32 pm »
Today bought 2 new Revell liquid glue for plastics 25 g (Blue container with yellow cap and metal needle).
Taranis
  • Balne Moor MBC
« Reply #178 on: February 09, 2019, 02:44:51 pm »
I'm not sure of the best way to store them. I always have a blocked nozzle with dried glue  {:-{
ANDY
« Reply #179 on: February 09, 2019, 02:49:04 pm »
in the past used thinners after removing the needle - as it dries reasonably close to the end the other end is sometimes still wet and can be cleaned out - but not always.
Taranis
  • Balne Moor MBC
« Reply #180 on: February 10, 2019, 10:32:53 pm »
I’ve used this a number of times today and each time stood the bottle upside down with success  :-))
Moving on
I bought these tiny brass split pins
Not many left! Price seemed good ?
I believe some modellers use similar for fixing brass grab rails to life boats etc
https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.co.uk%2Fulk%2Fitm%2F112580748922
ANDY
« Reply #181 on: February 11, 2019, 08:49:07 am »
I bought some side cutters and a pair of needle nose pliers for work. The former we break regularly when clipping parts off of pewter sprues and the latter to augment an old pair that I have modified beyond where they help form rings.
Also, I bought two new needle files of rougher cut, a bottle of CA and a wearable magnifier to reduce strain on my eyes as I lose focus after a few hours at work even with lunch and a tea break in between.
For the Armoured Cruiser, I will be buying lots of goodies  :-) Mr Haynes, SLEC and Mtroniks will get a call and probably 'Deans'.
Taranis
  • Balne Moor MBC
« Reply #182 on: February 11, 2019, 08:52:06 am »
I have many assorted files but they are now all suffering from solder filling the cut. I’m considering putting a blow torch on each one whilst using a file cleaning brush. Any one got a better idea?
ANDY
LJ Crew
« Reply #183 on: February 11, 2019, 09:04:51 am »
Hi Andy, don't heat the file too much, it will lose it's temper and go blunt very quickly. A steel wire brush is the best I've found. John
Taranis
  • Balne Moor MBC
« Reply #184 on: February 11, 2019, 09:16:19 am »
I have one John but it’s no use in the very fine files unfortunately
ANDY
grendel
« Reply #185 on: February 11, 2019, 12:24:57 pm »
steel wire brush in a dremel?
« Reply #186 on: February 11, 2019, 08:14:05 pm »
I set to with an old compass point and scrape the kerfs out. Once you get into a routine it gets quite quick! A tip for filing soft metals is to rub the teeth with talc before filing as this seems to reduce/prevent the kerfs from gumming up.
Taranis
  • Balne Moor MBC
« Reply #187 on: February 11, 2019, 10:44:26 pm »
Good tips thanks Ian
A lot of my files are too fine for a compass point and may be beyond recovery
ANDY
« Reply #188 on: February 11, 2019, 10:57:31 pm »
Give the point a sharpen and see what gives (Lead solder hopefully!)
david48
« Reply #189 on: February 11, 2019, 11:40:35 pm »
I bought a Wavetek  20MHz oscilloscope model 9020 .Bought at a club auction for £22. I do not know why ,the auctioneer said if you have not got one you have no use for one ,when you get one you did not know how you managed without it ....so time will tell ,OH by the way any one have probes for it .
David
Aradi
« Reply #190 on: February 12, 2019, 08:33:12 am »
New TV for a living room
C-3PO
« Reply #191 on: February 12, 2019, 09:27:52 am »
David
Hi David,
Some probes can run into hundreds of pounds!!
However - strange but true - checkout Amazon
C-3PO
Taranis
  • Balne Moor MBC
« Reply #192 on: February 16, 2019, 01:02:50 pm »
I'd been looking for a new multi charger due to my SkyRC one failing.
This has some good reviews and youtube vids so I thought it worth a punt.
Under £45 ebay or £65 ish Amazon
Quite small
ANDY
« Reply #193 on: February 16, 2019, 01:14:14 pm »
Two new front tyres for the car, it's going in for it's annual service MOT and some faults to be fixed - I think the clutch is going - oh dear.  >:-o
« Reply #194 on: February 16, 2019, 01:29:58 pm »
Clutch pedal???
Start practicing left foot
Braking :D :D :D :D
Taranis
  • Balne Moor MBC
« Reply #195 on: February 16, 2019, 01:30:34 pm »
Very much dreading the comfortmatic clutch and dual mass flywheel with a starting price of £1200  {:-{  only 55K on the van but these clutches have a reputation for failing in very much less mileage. We want to go to Spain later this year and I feel it may be best to bite the bullet and do it first
ANDY
« Reply #196 on: February 16, 2019, 01:38:50 pm »
Is it a Ducato?
The mind boggles how manufacturers of
Rv's that will obviously do high mileages
fit a known weak link.
It's not like you've bought a 15 grand runabout.  >>:-(
Taranis
  • Balne Moor MBC
« Reply #197 on: February 16, 2019, 01:43:04 pm »
Is it a Ducato?
Yes Ned but Fiat use the Iveco engine for the 3.0 and 2.3 litre. It's a 2008 left hand drive.
Probably have it done over at CamperUK Lincoln way
ANDY
Dave_S.
« Reply #198 on: February 16, 2019, 04:42:49 pm »
My modelling purchases this week have been limited to a set of light wind sails and rig for the DF 65 I bought a week or so earlier. I took it out in fairly calm conditions last week for its (and my) first sail and it was suggested that an A+ rig would be a wise purchase.
Mark T
« Reply #199 on: February 16, 2019, 05:59:10 pm »
Quite small
I've got something similar to this - I found that the programming takes a bit of sorting out but once done they are great bits of kit.  This week I've bit the bullet and ordered a thickness sander as my woodworking is getting better and its a bit of kit to help me through retirement in 15 years time  {-)
Pages: 1 2 3 4 5 6 7 [8] 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 ... 61   Go Up
Page created in 0.116 seconds with 22 queries.
