Author Topic: Tank Steering or mixer  (Read 3153 times)
essexbill
« on: April 29, 2018, 07:55:42 am »
Hi.
Yet another question.
I have recently purchased a MMM "Nantu" that needs the electrics completing.
2 steerable Korts nozzles fitted.
Someone suggested a mixer unit and ANDY at MMM suggested tank steering.
My only concern with Tank Steering is keeping her running straight rather than a zig zag pattern.
What are peoples thoughts or experiences please.
kinmel
Re: Tank Steering or mixer
« Reply #1 on: April 29, 2018, 08:01:23 am »
All my twin prop models are on tank steering, easy once you have mastered the basics.
I have used mixers in the past and they do a good job as long as both motors perform equally.
Tank is much cheaper !
Bob K
  • Bob K
« Reply #2 on: April 29, 2018, 08:28:15 am »
It is largely a matter of preference.  Both systems work well.
Myself I prefer a good mixer system for multi-motors.
eg:  Action Electronics P94 from Component Shop.  Dual 20A ESC's with various modes of mixing (switchable) and internal pot to adjust how the proportional mixing operates.
Butts
  • Secretary, Balne Moor Model Boat Club
    • http://balne-moor-model-boat-club.myfreesites.net/
« Reply #3 on: April 29, 2018, 08:33:42 am »
I mentioned a mixer as a option with the P94 as Bob has explained.
For tugs I would always recommend tank steering as the first option. Most people can manage to master the method, but others find it alien.  With the P94 you have the option.
steamboat66
  • maybe it will float!
« Reply #4 on: April 29, 2018, 08:54:27 am »
having flown multirotors in the past, i may find a mixer preferable. i'll cross that bridge eventually. try both, on other peoples boats.
« Reply #5 on: April 29, 2018, 09:07:39 am »
Do mixers allow you to run one prop forwards and the other backwards?
Bob K
  • Bob K
« Reply #6 on: April 29, 2018, 09:11:51 am »
Yes, that is one of the usual options provided.  Good for Tugs and Springers.
Long thin Warships usually work best with the inboard prop slowing on the turn.
See  http://www.action-electronics.co.uk/pdfs/P94.pdf  for full options
steamboat66
« Reply #7 on: April 29, 2018, 09:16:36 am »
you can blend the two with a forge electronics mixer.
« Reply #8 on: April 29, 2018, 10:36:02 am »
No need for a mixer on a springer O0
If it has more than one prop, it's not a Springer.
Jerry C
« Reply #9 on: April 29, 2018, 10:49:35 am »
If you know how to set up a twin screw vessel and drive it then use tank steering. If you don’t then use a mixer. As a past skipper of AHTS vessels I prefer tank steering with independent rudders. It allows you to walk a boat sideways without a bow thruster.
Jerry.
cos918
« Reply #10 on: April 29, 2018, 06:29:12 pm »
I use tank steer on my Ferries .
1 set the power port  and adjust on starboard to get get straight running.
2 when feeling lazy and wont to go slow to conserve batteries use one motor and kick the rudder over a bit .
3 you have far more control with tank steering than a mixer can ever do .
Page created in 0.351 seconds with 17 queries.
