Author Topic: Laminating extruded polystyrene?  (Read 3608 times)
aamcle
« on: July 24, 2018, 06:26:44 pm »
I've found a source of reasonably priced extruded polystyrene, now after a huge amount of reading I'm still looking for a bit of guidance.
I know I can use Gorilla glue but is that the best option for larger sheets?
How much trouble is the glues expansion?
Does it interfere with a hot wire cutter?
Are there any other options, spray glues or ........?
Thanks All.        Aamcle
aamcle
Re: Laminating extruded polystyrene?
« Reply #1 on: July 24, 2018, 07:35:45 pm »
Also :-
Uhu Por for foam
Aamcle
aamcle
« Reply #2 on: July 25, 2018, 07:55:48 am »
Soudal Pro P45 Polyurethane like Gorilla but cheaper on evilbay.
Aamcle
Big Ada
« Reply #3 on: July 25, 2018, 05:25:37 pm »
I do not know what you are building but, I went to a local Builders Merchants to buy Slab Insulation Foam, when I told the Bloke in the yard what I wanted if for he pointed me to some damaged off cuts for free.
aamcle
« Reply #4 on: July 25, 2018, 05:50:31 pm »
Non of the local merchants including the big chain merchants stock Extruded Polystyrene just boards made from polyisocyanurate which apparently does not cut well with a hot wire.
Atb.           Aamcle
Big Ada
« Reply #5 on: July 26, 2018, 05:21:29 pm »
Then Maybe use a wood Saw.
Atb.           Aamcle
