Author Topic: Glueing new wooden deck to existing wooden deck  (Read 3939 times)
goBulawayo
« on: August 09, 2018, 05:54:34 am »
Hi All, I want to put a new deck onto a boat I am rebuilding, the old one is a bit tired, full of holes etc - The new deck will probably be 1mm ply as I have some in stock, I am not sure what glue would be best - I have been using Gorilla glue for odd jobs on boats recently and wondered if I could use that?
Cheers Wayne
Footski
Re: Glueing new wooden deck to existing wooden deck
« Reply #1 on: August 09, 2018, 08:42:22 am »
I feel the old deck is bad wood with no varnish or paint finish, you can just use a decent waterproof pva wood glue. That should hold it very nicely.
nemesis
« Reply #2 on: August 09, 2018, 06:09:44 pm »
Good old cascamite, plenty of time (24hr) and waterproof. nemesis
Footski
« Reply #3 on: August 09, 2018, 07:06:23 pm »
Blimey, can you still get that?  :-)) :-)) :-))
John W E
  • I see no ships !!
« Reply #4 on: August 09, 2018, 07:20:08 pm »
https://www.swanseatimber.co.uk/adhesives-and-tapes/wood-glue/CASCAMITE-Adhesives-Wood-Glue-1-5kg/prod_4023623.html?utm_source=bing&utm_medium=cpc&utm_campaign=STP%20Shop%20Merchant%20Product%20Ads&utm_term=4574861725055646&utm_content=Ad%20group%20%231
and also from Amazon and Screwfix sells it
I personally like to use the yellow glue - Titebond glue - from Amazon etc.   I find it works well -
Cascamite I find does deteriorate over years and leaves a white powder when you separate the bond - mind - I am talking 20 years plus.
Knowledge begins with respect
nemesis
« Reply #5 on: August 11, 2018, 06:10:53 pm »
aye John, you are a strong man, I have never been able to separate a cascamite joint, Good enough for the RAF, that is enough for me. keep well, nemesis
« Reply #6 on: August 11, 2018, 06:20:43 pm »
For everything that went in water  we always used Aerolte.
PBK canoe frames, pram dinghies and such..
One canoe built in 1959 has been recanvassed five or six times
The frame is original
