Hi all,
Dicky, the idea behind 100% reverse brake is you only apply it until the model stops, the other reason your model digs in is its got a flat transome or blunt end. You will note if you reverse any flat stern boat at any speed over a crawl it will tend to 'dig in'. This was one of the biggest problems they had with the design of MTBs, also, Air Sea Rescue boats during and after the war. The flat stern also contributes to bad sea keeping in following seas, it tends to add to the problem of the vessel broaching. Whereas, the back of the boat tends to overtake the front of the boat.
The good side of a flat stern is, when the propellors are mounted near the stern of the vessel, it creates a lifting property, which brings the boat onto the plane quicker.
Its all to do, my friend, with the vacuum created at water level at the back of the boat, as the boat moves forward.
aye
John e
bluebird
a bit off topic, but nevertheless, it may answer some questions :)
