Pages: 1 [2] 3   Go Down
Author Topic: Speedline Tamar Lester 1/12  (Read 21887 times)
Holger
Re: Speedline Tamar Lester 1/12
« Reply #25 on: December 30, 2018, 12:23:30 pm »
yes Gingyer ..
that's exactly what I meant .. it's just the measure to see the keel. , the other measure is unfortunately no longer visible in the picture and that's what I was still looking for ..
I wish you and your family a happy new year ..
Holger
« Reply #26 on: December 30, 2018, 12:27:54 pm »
thank you Lance ..
These are the dimensions that I was looking for .. !!!
Holger
« Reply #27 on: January 01, 2019, 02:01:41 pm »
it continues with your help ..
marked the line for the rudder and stern tube feedthrough and started to drill ..
I hope it is on the pictures to recognize that although the teaching with the stern tubes exactly in the middle of the keel was the left circle 5mm lings further lay .. I have therefore made a cardboard template and so drawn the line in the middle of the tunnel afterwards ..
Holger
« Reply #28 on: January 01, 2019, 02:26:44 pm »
here are the pictures ..
Holger
« Reply #29 on: January 03, 2019, 09:17:18 am »
good Morning
I would soon like to install the shaft system .. now I have seen that the threaded piece is very short .. if I turn the ship's screw on it is no more space for a lock nut ..
How did you do it .. ?? a picture would be great ..
thanks in advance, Holger says
furball
« Reply #30 on: January 04, 2019, 04:35:00 am »
Probably not what you want to hear, but I bought new shafts.
Lance
Holger
« Reply #31 on: February 24, 2019, 07:24:24 pm »
Now I'm a bit further ..  :-)  The openings for the two stern tubes are drilled .. the holes for the lower water inlets marked .. the keel extension is glued and the adjustment to the keel is also grout and sanded .. unfortunately I only after the adhesive was already dried on a photo of the original seen the keel area between the trunk and the keel extension to the end is tapered and half round .. that cost me a lot of time because I have so bad with tool to change / grind I would have come .. if I had cut out the keel extension again, I would have better come to the grinding but it would have cost me even more time with the re-adjust and wait until the glue is dry again for it .. but I am satisfied with the result anyway. ,
the tailgate is also finished except for the upper side and I can start with the other fit into the trunk .. when the finished is still the recess for the four-part flaps on the back deck off ..
also the openings for the bow thruster are drilled ..
GOD THANKS to you the filling and especially the grinding slowly towards the end ..
alan44
« Reply #32 on: February 24, 2019, 07:47:19 pm »
That looks like a pretty poor quality moulding to have supplied!! Lots of making good.
alan44
« Reply #33 on: February 24, 2019, 08:03:34 pm »
The finished stern.
Taranis
  • Balne Moor MBC
« Reply #34 on: February 24, 2019, 08:04:50 pm »
Your work is always so precise Alan even if upside down  :-)
ANDY
alan44
« Reply #35 on: February 24, 2019, 08:06:46 pm »
It's ok on my IPad  :-))
Holger
« Reply #36 on: February 24, 2019, 08:32:51 pm »
Oh yes Alan .. I'm more than happy when I'm done with the spatula and grind .. I'm sure 30/40 hours just swallow the grinding dust ..
Thank you for your great photo and I hope that I come even close to your nivau ..
have the luck to be in contact with a mechanic of the cromer station who helps me with questions about technology and details with pictures and antorten very ..
alan44
« Reply #37 on: February 24, 2019, 08:36:42 pm »
Al
Holger
« Reply #38 on: March 03, 2019, 12:30:50 pm »
Now I thought that I am almost finished with the spatula and grind and now that although I have seen the picture often I am the error between the kit hull and the original - the Kontuten in the red circle - so far not noticed .. but still better now than later when the model is almost done ..
So I stuck with thin wooden strips a small form to the tailgate and filled with my 2-component filler .. maybe this evening when it is dried it is sanded and then adjusted in the next days in the hull ..
but it is called "MODEL BUILDING" .. O0 O0 O0
alan44
« Reply #39 on: March 03, 2019, 09:41:10 pm »
The picture Holger has shown is difficult to understand if you don the know the boat.
Here's a shot of the drop down tail gate completed.
Holger
« Reply #40 on: March 04, 2019, 05:43:21 pm »
yes Alan .. and please excuse all others .. here is a picture of the original ..
around this area of the tailgate, it was ..
Holger
« Reply #41 on: March 04, 2019, 07:26:20 pm »
a corner is almost finished .. it is the circled corner from the top picture
Holger
« Reply #42 on: March 08, 2019, 02:08:23 pm »
I needed a break from the spatula and grind and there was soldered .. looks really funny .. but it should be so .. after screwing the parts, I can then adjust the opening for the tailgate exactly ..
Holger
« Reply #43 on: April 01, 2019, 07:32:01 pm »
yesterday I could do something further .. the recess for the four-piece flap was recorded and then roughly cut .. in the pictures you both sides see .. the original recess and the current .. a lot of work .. !!! Adrian did not do such a good job .. was it in your kits synonymous ..? !!!
Holger
« Reply #44 on: April 22, 2019, 07:34:19 am »
Now I have both controllers - Turnigy Marine ESC 90A - programmed and if I plug them individually at the receiver you run .. because I want to run both motors s.einer receiver channel I have heaped on a regulator + cable and with a Y-cable with connected to the receiver .. now but only the engine runs with the three cables and where I pulled out the + cable beeps only as not yet programmed ..
what is not working .. ??
Holger
« Reply #45 on: April 26, 2019, 07:25:37 pm »
Hi .. Now I'm going to fix the location of the electrics .. here's a first try .. but it will certainly be a second minor level to come and a small pump for the cooling water for the two controllers .. what do you think of mine arrangement. . ?? How did you do it . . ??
Holger
« Reply #46 on: August 04, 2019, 06:03:51 pm »
Hi Taranis / Andy ..
 on the first page at the bottom of your two pictures is a cooling water pump to see .. can you please send me data from the pump or send a link where you have the pump ago .. ??
Taranis
  • Balne Moor MBC
« Reply #47 on: August 04, 2019, 06:40:09 pm »
Hi Holger
These pumps change all the time on eBay as stock sells out. The ones I bought are advertised as 12 volts but run happily at much less like 5volts
Just search eBay for self priming micro pumps for a selection
ANDY
Holger
« Reply #48 on: August 04, 2019, 07:12:43 pm »
that is her ..
https://www.ebay.co.uk/itm/MagiDeal-Durable-12-V-DC-350mA-Micro-Mini-Wasserpumpe-Tauch-5-45-1/123772557534?hash=item1cd16b58de:g:2fcAAOSwexlc4H86]https://www.ebay.co.uk/itm/MagiDeal-Durable-12-V-DC-350mA-Micro-Mini-Wasserpumpe-Tauch-5-45-1/123772557534?hash=item1cd16b58de:g:2fcAAOSwexlc4H86
Taranis
  • Balne Moor MBC
« Reply #49 on: August 04, 2019, 07:14:35 pm »
Yes but you should find for lower price
EDIT maybe not just now unfortunately but yes that is it  :-))
ANDY
Pages: 1 [2] 3   Go Up
Page created in 0.291 seconds with 17 queries.
