Author Topic: USEFUL STUFF  (Read 3208 times)
Re: USEFUL STUFF
« Reply #1 on: November 20, 2018, 11:51:41 pm »
Are these any good>--https://www.banggood.com/Paron-JX-D5301-Multifunctional-Ratchet-Crimping-Tool-Wire-Strippers-Terminals-Pliers-Kit-p-1175325.html?currenccriteoy=GBP&utm_source=&utm_medium=cpc&utm_content=all&utm_campaign=tools-gb-en&cur_warehouse=CN
I suppose if you are doing a lot of electrical stuff as a profession...…..priceless...…….but as a modeller...……….I have never needed such a tool in 50 years where a good set of pliers wouldn't suffice.     sorry to be the harbinger of doom and gloom, but I only buy tools that I know  will use frequently.
C-3PO
Re: USEFUL STUFF
« Reply #2 on: November 21, 2018, 08:34:31 am »
Hi John,
I have a pair of wire strippers/cutters of the same style as the one in the top part of the case in the picture - not the same brand but they look the same (possibly a tool from one manufacturer sold under many different brand names - or a copy which may lead to a quality issue!)
Using them was a true revelation - stripping wire is simple, fast and accurate - brilliant piece of kit I wish I had purchased years ago -  I have owned a few wire cutters/strippers - mainly cheap ones that where average to poor in usage which I used/use extensively in my other hobbies of amateur radio / electronics
C-3PO
grendel
Re: USEFUL STUFF
« Reply #3 on: November 21, 2018, 11:24:41 am »
lidls had a set of wire strippers recently, I recall, at not too much money, I got a set and they do come in useful.
Re: USEFUL STUFF
« Reply #4 on: November 21, 2018, 11:59:09 am »
I have a set from Screwfix or Toolstation, they are !interesting"!
As C3P0 says not very useful to modellers unless you are doing a Lot of wire stripping.
NB: Not that good on small wires, needs quite a bit of 'fine tuning'.
But a great "fun" too but you may find you spend more time looking for it than using it!
david48
Re: USEFUL STUFF
« Reply #5 on: November 21, 2018, 11:38:36 pm »
The wire strippers are good , my reason they can be used in confined space . You just grip so hand control is just that controlled, not a sudden movement when the insulation comes off . did not use crimps all connectors are or should be soldered .
David
Re: USEFUL STUFF
« Reply #6 on: November 21, 2018, 11:50:00 pm »
Apart from all my tools which I have built up over the many years of modelling, both hand and power tools which I use regularly, some on almost daily basis...............this little tool is probably one of my most useful and well used tools,,,,,,,,,,,,so much used, that I bought two of them, and had a 3rd given away free to me...........a mini tube/pipe cutter.
a simple thing...…...but so well used and irreplaceable.
Re: USEFUL STUFF
« Reply #7 on: November 21, 2018, 11:54:58 pm »
Quite agree Neil, those little tube cutters are really useful. I have a couple of small ones and a bigger one capable of dealing with 13mm copper pipe.
Another good value tool which comes in very handy is this guillotine.https://www.ebay.co.uk/p/Proops-Multi-Angle-Craft-Hobby-Guillotine-Modellers-Miniaturist-C6035/1007610270?iid=292049339411&chn=ps
Page created in 0.196 seconds with 17 queries.
