Author Topic: Kort Nozzle  (Read 3251 times)
rickles23
    • Royal Navy Commandos
Kort Nozzle
« on: December 03, 2018, 08:41:51 am »
HI, Advise needed for the installation of a kort nozzle from the beginning.
I have never installed one before.
I have drilled the holes and the prop shaft and rudder tube are a snug fit.
The stern is in the shape of an inverted L and bth are flat panels and the holes are drilled dead centre.
NickelBelter
Re: Kort Nozzle
« Reply #1 on: December 04, 2018, 04:43:08 pm »
What I've seen people do is make up a circle template of the same OD as the ID of the nozzle and a center hole for the propshaft, and use that in place of the propeller to ensure the nozzle is centered on the shaft.
rickles23
Re: Kort Nozzle
« Reply #2 on: December 07, 2018, 02:40:48 pm »
Hi NickelBelter,
I did not know it was that easy.
Thank you for your help.
Re: Kort Nozzle
« Reply #3 on: December 07, 2018, 03:55:43 pm »
I would suggest that the diameter of the circular template was 1-2 mm greater than that of the prop.
Re: Kort Nozzle
« Reply #4 on: December 07, 2018, 04:17:07 pm »
As long as the ID of the nozzle is the same.
Taranis
  • Balne Moor MBC
Re: Kort Nozzle
« Reply #5 on: December 07, 2018, 04:25:04 pm »
ANDY
Re: Kort Nozzle
« Reply #6 on: December 07, 2018, 04:32:13 pm »
That's the way to do it :-)) :-))
Mark T
Re: Kort Nozzle
« Reply #7 on: December 07, 2018, 05:25:15 pm »
Yep and me - for some reason Mr Muscle oven cleaner tops were the perfect fit for these ones  :-))
Taranis
  • Balne Moor MBC
Re: Kort Nozzle
« Reply #8 on: December 07, 2018, 06:51:01 pm »
And never has there been a nicer cleaner smoother bottom Mark  :-)) {-)
ANDY
Mark T
Re: Kort Nozzle
« Reply #9 on: December 07, 2018, 10:07:22 pm »
It was a few years ago as my wife would tell you  {-) %%  now get those korts sorted  :-)) :-)) {-)
rickles23
Re: Kort Nozzle
« Reply #10 on: December 09, 2018, 08:38:27 am »
Hi all,
The nozzle is now set up and ready to be glued in place.
I could not find a bottletop to fit but the hole saw gave me the right size.
