Author Topic: 1970s 48 inch Huntsman  (Read 3554 times)
Biscuit
« on: February 10, 2019, 10:09:41 am »
Hi all just a short vid of my old Huntsman in the rough.
https://youtu.be/Q5roBYFn3t0
coch y bonddu
Re: 1970s 48 inch Huntsman
« Reply #1 on: February 10, 2019, 12:33:17 pm »
What motor or motors have you in that whats the spec,as that goes rather well
Leaky Bottom
« Reply #2 on: February 10, 2019, 03:23:43 pm »
Sounds like it's an IC engine to me, probably a 10 to 15cc in a 48" huntsman
"Leave me alone I know what I'm doing"
martno1fan
« Reply #3 on: February 10, 2019, 04:25:36 pm »
Goes well sounds like a zenoah in there ?.
Davo
« Reply #4 on: March 26, 2019, 06:56:07 pm »
The Huntsman hull, as with the real thing, really can handle any water conditions. Great to see a boat in action like that.
David
David
olly4950
« Reply #5 on: April 18, 2019, 09:44:38 pm »
Hi, I have a T600 brushless in mine.WoW is she fast!
zooma
  • Never too old to learn !
« Reply #6 on: May 19, 2020, 12:31:44 pm »
I have just seen this motor on the HK site and it looks perfect for a project that I have in mind.
Can you let me know what size prop you are using please and advise if a 150amp speed controller would be OK to use with either three or four cell LiPo's please?
Also, have you found a water-cooled mount that can be used with this motor, or do you use fan cooling instead?
Thanks for your help,
Bob.
olly4950
« Reply #7 on: May 19, 2020, 07:57:34 pm »
I have a 180amp Seaking esc .
The prop is a 52.5 nylon prop.
zooma
« Reply #8 on: May 19, 2020, 08:36:15 pm »
Thanks Olly,
Do you have a water-cooled motor mount, do you use a fan to cool the motor,  or do you not need to cool the motor at all?
Your help with this would be appreciated as I cannot find a water-cooled mount that this motor will fit.
Thanks,
Bob.
olly4950
« Reply #9 on: May 20, 2020, 10:58:15 am »
I have a water cooled mount.
No other means of cooling.
Because the T600 is an out runner it's only the bearings at the front end that get cooled.
The mount I used was a watercooled 540 mount
On ebay search for
540 water cooled brushless motor mount and fiber stand for electric rc boat 1762.
This is the type your looking for but make sure the dimensions for the orange part are 53mm, I had to file the slots in order to get the T600 to fit.
Hope this helps?
zooma
« Reply #10 on: May 20, 2020, 09:54:08 pm »
Thanks Olly,
I will use your search info to find one.
Stay safe!
Bob.
Page created in 0.283 seconds with 18 queries.
