Author Topic: glazing wooden windows cut outs in plywood  (Read 3001 times)
Gardener
« on: March 04, 2019, 07:26:02 pm »
what is the best way to glaze window cut outs
what material to use as glass and which glue is best ?
thanks
rnli12
Re: glazing wooden windows cut outs in plywood
« Reply #1 on: March 04, 2019, 07:36:02 pm »
Perspex or acetate sheet   :-))
« Reply #2 on: March 04, 2019, 07:44:05 pm »
If you have space then a bit of stripwood below the window to rest the glazing on is good. Use canopy glue to fix the glazing in place as you can remove any surplius. NEVER use standard cyano (superglue) as it clouds the transparency.
Gardener
« Reply #3 on: March 04, 2019, 07:56:46 pm »
 :-))  thanks
Taranis
  • Balne Moor MBC
« Reply #4 on: March 04, 2019, 08:44:08 pm »
Good advice but I chose to show off my window frames by using invisible glazing  :kiss:  From a distance who would know  :-)
ANDY
Gardener
« Reply #5 on: March 04, 2019, 08:47:14 pm »
nice quality model  :-))
« Reply #6 on: March 04, 2019, 11:07:11 pm »
There are two [2] Seakadett builds on this French WEB site....one guy in Switzerland & one in France...
The method and build construction for the window glazing is absolutely brilliant.....[no pun intended]...... Derek
http://modelismenavalvapeur.forumactif.com/t513p100-construction-d-une-chaloupe-du-lac-leman-a-la-seekadett#2076
http://modelismenavalvapeur.forumactif.com/t576p25-seekadett-tout-simplement#1838
Gardener
« Reply #7 on: March 05, 2019, 08:19:23 am »
Page created in 0.247 seconds with 18 queries.
