Author Topic: motor mount  (Read 2226 times)
Holger
motor mount
« on: May 06, 2019, 07:45:27 pm »
MOTOR MOUNT ..
Does anyone know this one here or maybe you have already installed it ??
she tells me a lot about the alignment of motor and screw shaft seems to be 100% tig and so the alignment of the two should be omitted..
Hotglove
Re: motor mount
« Reply #1 on: May 18, 2019, 11:51:55 am »
Not familiar with this mount but I installed a mount intended for model aircraft in my Dumas Runabout and found that, after a bit of drilling and filing to convert it to marine use that the adjustability made it a pleasure to set up motor/shaft alignment.  The one I used is marketed in two sizes by Great Planes and needs to have the motor mount turned through 90 degrees. First photo has a slight lens distortion, it does line up exactly, really  ok2  the rubber coupling and corresponding lining up coupling came from Model Boat Bits (very helpful) Good luck
ChrisF
  • What's my favourite cake!
Re: motor mount
« Reply #2 on: May 18, 2019, 12:50:53 pm »
Won't be long before I fit the motors in my builds and that mount looks great to get accurate alignment.
Chris
Holger
Re: motor mount
« Reply #3 on: May 25, 2019, 01:07:34 pm »
Hoi Chris .. thanks for the pictures and the descriptions .. I found the motor mounts at greatplanes and siw look very good .. !!! unfortunately I miss measurements of the individual holder ..
