Author Topic: Annimating turrets  (Read 2861 times)
pokherman
Annimating turrets
« on: May 22, 2019, 08:26:50 am »
Hello people...
I need some ideas as to how to animate my turrets on the Manxman..  Dont think I want to use Arduino, too much involved and a lot of wires..
I was thinking of using geared pulleys with some sort of mini timing belt. If I can somehow fix the pulleys to the servo I think it could work...  I need to make sure that I can get to the servos should anything go wrong with them, hense why I dont want to use direct drive.. I could use the traditional method of arms and bent control rods I know. but I dont think I can get the rotation I want,,  if I fit a larger toothed pulley onto the servo and a smaller one say half the size, in my head this would make the smaller one turn twice the rotation of the servo..
The trouble is , im having a hard time locating such pulleys and belts.. obviously the belts need to be narrow as there is not going to be much in the way of pressure to turn, Im going to run a shaft from each turret through two small bearings fixed in place to give extra smooth turning.
So does anyone know where or who I can talk too or look for bits etc... or does anyone have any better ideas??
some help would be great.
Cheers Ian
aeronut
Re: Annimating turrets
« Reply #1 on: May 22, 2019, 08:58:31 am »
If you can keep the turrets free turning, then simple pulleys with elastic bands for belts ought to suffice.  Otherwise, gearing is one solution, but quite a bit more complex
Gordon
Geoff
« Reply #2 on: May 22, 2019, 01:35:37 pm »
As an option make up your own bowden cables using the "net curtain stretchy white line stuff" with fishing line inside. This will let you turn anything anywhere with the drive motor or servo being remote. It does not have to be tight and works very well.
You can get "servo slow" devices which just plug in if you don't have this feature on your transmitter of if there is not enough movement in a standard servo for what you want use a servo sized sail winch and again adjust the end points and speed on the transmitter. Again electronic devices are available if this is not a feature on your transmitter.
Hope this assists
Geoff
marinaru_ro
« Reply #3 on: May 22, 2019, 02:11:06 pm »
I've made mine, for 1/200 Bismark using nano servos. The sound and smoke are independently controlled from RC
George
Geoff
« Reply #4 on: May 22, 2019, 02:13:23 pm »
Neat, so how do you make the smoke and pump it out?
Geoff
marinaru_ro
« Reply #5 on: May 22, 2019, 02:14:31 pm »
Small smoke generator, from Seuthe. It's going out using a small air pump and a valve
pokherman
« Reply #6 on: May 25, 2019, 07:59:24 am »
thanks for the help guys..
Still looking and thinking..
does any one know where you can get the small toothed belts and pulleys from???   ones they use in printers etc
Ian
Plastic - RIP
  • Inactive
  • Bobbing Along!
« Reply #7 on: May 25, 2019, 08:19:08 am »
Ian
Look on ebay under robotics and models
John W E
  • I see no ships !!
« Reply #8 on: May 25, 2019, 08:49:06 am »
Knowledge begins with respect
NickelBelter
« Reply #9 on: May 30, 2019, 10:54:52 pm »
What diameter are the turret bases/barbettes on this 'Manxman'?
grendel
« Reply #10 on: May 31, 2019, 11:38:45 am »
3d printer suppliers- or stripping down old inkjet printers
grendel
