Author Topic: 'Holding' small parts for airbrushing  (Read 3213 times)
justboatonic
« on: July 01, 2019, 12:18:53 am »
What do people use for holding multiple small parts for airbrush painting? Yes, you could use a couple of croc clips in a Helping Hand type gizmo but that effectively means you can only do 2 at a time and have to wait for them to dry before replacing with two more.
Some years ago, I think there used to be a product called Sticky sticks or something which were like cocktail sticks with a sticky end?
Anyway, when you've loads of small parts you want to airbrush, what do you use? Having grey fingers doesnt look good!
Peter Fitness
Re: 'Holding' small parts for airbrushing
« Reply #1 on: July 01, 2019, 01:08:46 am »
I made myself a turntable from an old microwave and use double sided tape to hold small items. Even without a turntable double sided tape on some scrap wood works well too.
Peter.
KitS
« Reply #2 on: July 01, 2019, 06:48:17 am »
BluTack!  :-))
Kit
« Reply #3 on: July 01, 2019, 11:29:29 am »
I'm with Peter, double sided tape every time. Stuck to a long piece of wood which you can manoeuvre as required.  :-))
Bob K
  • Bob K
« Reply #4 on: July 01, 2019, 02:23:32 pm »
I agree, double sided tape is ideal.
I also include a strip of masking tape which I write the part references underneath, so when paint is dry I can fold the tape over to reveal the part references.
justboatonic
« Reply #5 on: July 02, 2019, 01:36:10 pm »
A-ha! Never thought of double sided tape. Thanks all.
DaveM
  • Why on earth do I do this?
« Reply #6 on: July 02, 2019, 01:51:54 pm »
Of course if you're a cheapskate like me then you can use ordinary masking tape, held sticky-side-up with a short piece of tape at each end to hold it down and tension it. I found that the adhesive on most double-sided tape is often a bit too sticky and leaves a residue on the parts - and it's a lot more expensive than the budget B&Q stuff!  8)
DaveM
« Reply #7 on: July 02, 2019, 04:25:17 pm »
I just use blue masking tape, form a loop sticky side out and then flatten it onto a flat surface. Works OK in most situations and dead cheap as Dave says.
Mark T
« Reply #8 on: July 02, 2019, 07:10:27 pm »
If you do want to use clips there are loads on Ebay. Here’s some £4.49 for 20 clips they just need attaching to a metal or wooden rod
https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.co.uk%2Fulk%2Fitm%2F323650893782
CGAux26
« Reply #9 on: July 02, 2019, 09:31:11 pm »
I too use tiny alligator clips, hung on short pieces of wire.  Hang them anywhere that's convenient-a horizontal string or wire, a large can, etc.
Page created in 0.389 seconds with 18 queries.
