Author Topic: RN Type 42 Batch 1 & 2 non modified air intakes  (Read 9041 times)
justboatonic
« on: July 21, 2019, 06:55:52 pm »
I have another question regarding, in particular, HMS Newcastle but also the early T42 B1 & 2 non modified air intakes build.
Hopefully the attached pics of the ship and model build will help to explain the question.
On the B1 & 2, the non modified air intakes butt upto the superstructure and serve almost as another deck. In this pic, you can see a couple of crew members stood on top of the intakes.
The model build shows a little better.
My question is, how did the crew access the deck on top of the air intakes? All the pictures I have do not show any doors on the next higher deck superstructure and none show any steps or stairway from the deck immediately below the Scot Domes or Optical Lookout Sights level.
Does anyone have any pictures or planned layout showing steps or stairway?
Thanks in anticipation.
Re: RN Type 42 Batch 1 & 2 non modified air intakes
« Reply #1 on: July 21, 2019, 07:45:12 pm »
There appears to be a doorway under the dome platform and a short stairwell to the top of the air intakes (1st photo)
Also a walkway heading ford'?
justboatonic
« Reply #2 on: July 21, 2019, 10:11:31 pm »
I thought that as well Captain (in the first picture of Newcastle) and this is the only picture I can find that suggests there's some form of stairway and, there doesnt seem to be any other access methods ie doors either side of the mast base or, up \ down ladders on the sides of the intakes.
Would be good if I could get any other verification though.
« Reply #3 on: July 21, 2019, 10:46:15 pm »
There's another pretty good view here
https://www.flickr.com/photos/kev_slade/8149092422
mudway
  • Model Boat Mayhem is Great
« Reply #4 on: July 22, 2019, 12:31:58 am »
Another shot under the dome platform.
justboatonic
« Reply #5 on: July 22, 2019, 11:27:43 pm »
Thanks for the additional pics but they dont show crew access from the optical lookout sight deck to the deck space on top of the unmodified air intakes.
« Reply #6 on: July 22, 2019, 11:50:10 pm »
Well, we'll keep searching for the definitive answer but I've almost convinced myself there will be a short stairwell between the two. Maybe 5 or 6 steps angled to suit  {:-{
D108
  • Etherow model boat club
    • My models
« Reply #7 on: July 23, 2019, 12:56:10 am »
Hello,
From memory ,I served on Exeter and Cardiff, there were a few rings of a vertical ladder to get up to that deck, there was never much up there as the deck in bolts to get the engines out.
Paul
justboatonic
« Reply #8 on: July 23, 2019, 12:47:52 pm »
Hi. Thanks for the info for which I am very grateful. I just didnt want people to think I was after pictures of the deck under the Scot Domes or the optical sights etc and them go off looking for such.
From the pictures Ive found and others, its pretty clear there's a way up there!
littoralcombat
« Reply #9 on: July 27, 2019, 09:53:45 am »
What D108 said regarding the three/four rung vertical ladder. The deck was two bolted soft patches, which when removed accessed the Olympus Plenum Chambers and the Downtakes. The Splitter boxes (long sections of trunking with perforated vanes, which helped steady the air flow) would be removed, followed by a large box bolted to the front face of the Engine Module, called a Cascade Bend. This contained a 90 degree set of guide vanes, which altered the intake air flow direction from vertically down to horizontally aft, into the Engine Air Intake.
Guide rails were fitted, and the Engine lifted out.
I seem to remember that when operational, the area served as a convenient storage space for Wicker Fenders.
Nice Model by the way, following your progress with interest.
Nige
justboatonic
« Reply #10 on: July 30, 2019, 09:35:29 pm »
Nige
Thank you and thank you for the information!
Rob47
« Reply #11 on: August 08, 2019, 04:06:24 pm »
Hope this shot helps, its  HMS Gloucester, so I know it batch 3 but think its the same access
I will finish this model
