Author Topic: UHU PLUS ACRYLIT EXPRESS Epoxy  (Read 9037 times)
1275mini
« on: September 14, 2019, 09:55:46 am »
Just bought two pack of this glue to start building my happy hunter to bed in prop shafts rudder posts and engine mounts
My problem is I need some help with mix ratio powder to liquid
Looked on web and uhu site but no luck some help please
40 years ago I did use on my Elke boat
But old age takes it toll On my  memory  <:(
DaveM
  • Why on earth do I do this?
Re: UHU PLUS ACRYLIT EXPRESS Epoxy
« Reply #1 on: September 14, 2019, 10:17:46 am »
I've found that the pack contains 4g of hardener and 26g of adhesive, so I'd suspect that's the ration to mix it.  https://www.sussex-model-centre.co.uk/uhu-plus-acrylit
DM
Stan
« Reply #2 on: September 14, 2019, 12:14:08 pm »
HI 1275 I have the tecnical sheets for this glue with scan this evening and post for all to see.
Stan. :-)) :-)) :-))
1275mini
« Reply #3 on: September 14, 2019, 08:50:32 pm »
All sorted now thanks to Stan  :-))
KitS
« Reply #4 on: September 14, 2019, 09:03:02 pm »
Where did you post them please?
That info would be very handy.  :-))
Kit
Stan
« Reply #5 on: September 14, 2019, 09:20:46 pm »
HI 1275 glad they arrived OK all the best with your build. If you visit Blackpool come and see me on the Kirklees stand. Ref the tech sheets unable to post should you need them pm me with other contact details
Stan. :-)) :-)) :-)) :-)) :-))
KitS
« Reply #6 on: September 15, 2019, 04:31:23 pm »
Thanks Stan, I'm much obliged for the data sheets.  :-))
Kit
SailorGreg
« Reply #7 on: April 22, 2020, 07:00:48 pm »
I have also just bought some of this glue and am unclear about the mix ratio.  The pack provides two little measuring spoons marked "1/2" and "1" but there is no indication of the amount of goo out of the tube to use, and no way provided to measure that.  Help!  Stan, is it possible to see the data sheets?  I'll PM you as well in case you don't get here very often.
Greg
« Reply #8 on: April 22, 2020, 09:12:36 pm »
Instructions:
  https://www.phillsmodels.com/product.php/uhu_plus_acrylit_30g/?k=:::5226814
The surfaces to be stuck must be dry and free of dust and grease. Roughen smooth surfaces.
Fill the mixing tub with strands of binder to between two of the marker lines. For every square covered by binder add one small measure (one large measure for every two squares) of hardening powder and mix thoroughly using the spatula. Apply a thin layer to both of the surfaces to be stuck together and hold in place for approx. 15 minutes.
There is no need to apply much pressure.
Stan
« Reply #9 on: April 22, 2020, 09:22:55 pm »
HI sailorgreg  I have sent you a pm  will send you both speck sheets for this glue. Please be aware this glue is now out of production you may find some by searching the web. Or if you are feeling flush Patex Stabalit express  is very similar but around £30 a box
Stan .
SailorGreg
« Reply #10 on: April 23, 2020, 10:35:58 am »
Thanks Martin and Stan - comprehensive answers!   :-))
Greg
Stan
« Reply #11 on: April 23, 2020, 10:54:40 am »
Hi two tech sheets  e /mailed to you.
Stan. :-)) :-)) :-)) :-)) :-)) :-))
SailorGreg
« Reply #12 on: April 23, 2020, 10:55:24 am »
Page created in 0.189 seconds with 18 queries.
