Author Topic: Brushless Motors for a Speedline Tamar Lifeboat  (Read 2838 times)
mk1
« on: January 08, 2020, 06:41:05 am »
Hi can anybody tell me what  brushless motors and ESC I can use in my Speedline Tamar Lifeboat. I am also asking what small motors are used in the radar on the Tamar. Thanks in advance
Taranis
  • Balne Moor MBC
ANDY
Taranis
  • Balne Moor MBC
Re: Brushless Motors for a Speedline Tamar Lifeboat
« Reply #2 on: January 08, 2020, 09:27:22 am »
deleted
ANDY
Taranis
  • Balne Moor MBC
« Reply #3 on: January 08, 2020, 09:38:26 am »
This is Courtesy of Steve Ryan. This is the model slipway 1:16 version but shows it's doable especially with your skills
Component shop do a tiny motor too but without seeing the physical size of yours I don't know if it will fit? very cheap too
ANDY
Taranis
  • Balne Moor MBC
« Reply #4 on: January 08, 2020, 09:51:32 am »
Here two motors for size comparison
I think the left one is too big but the right one could be made to fit
Next to my scratch made unit
ANDY
Taranis
  • Balne Moor MBC
ANDY
mk1
« Reply #6 on: January 10, 2020, 06:24:12 am »
Thanks Andy for this I will look into the smaller of the 2 geared motors, Have used the other type in my Shannon.
T888
Regards David
Taranis
  • Balne Moor MBC
« Reply #8 on: January 10, 2020, 09:53:52 am »
Interesting Dave. I see it is rated at 3volts and quite fast. What voltage is required to come down to sub 30 rpm? My Shannon uses the no longer available horizontal motor that fits in the T section but The Tamar has no concealment below the level of the radar body unfortunately otherwise I'd send John one of them
ANDY
Taranis
  • Balne Moor MBC
« Reply #9 on: January 10, 2020, 11:04:12 am »
I've just set up the £3.50 component shop motor and 1.4volts is about 30rpm 1.3volts is about right for a Shannon and it still functions at 1.1volts which is the lowest the regulator will go down to.
VIDEO
<iframe frameborder="0" scrolling="no" width="1080" height="1920" src="https://api.smugmug.com/services/embed/9143119260_RNPQ7LS?width=1080&height=1920&albumId=99361991&albumKey=WS8QJr"></iframe>
A friend on Shannon facebook just suggested a 1.2 volt battery. That might actually be perfect without a regulator  :-))
Late EDIT I've just timed it at 25rpm on 1.2 volt rechargeable so a very tiny bit slow but close enough to lowest of radar speed range
ANDY
T888
« Reply #10 on: January 10, 2020, 01:14:50 pm »
The one I use is the DCGear motor 206-108 see the revised link
https://www.precisionmicrodrives.com/product-catalogue/dc-gearmotor
I run them on 3volts and under load the radar rpm is 6-7 rpm
Regards David
Taranis
  • Balne Moor MBC
« Reply #11 on: January 10, 2020, 03:58:16 pm »
 :-))  very good
Looks like they also sell the same one as components shop but I doubt it's £3.50
ANDY
minimariner
« Reply #12 on: January 10, 2020, 04:33:32 pm »
                 Video of 1/16 scale Speedline Shannon radar running on 1.2volts
                  using Component Shop Micro-P motor.
                                                Bryan.
                                      https://www.youtube.com/watch?v=jSnLQcZ1h2M
Taranis
  • Balne Moor MBC
« Reply #13 on: January 10, 2020, 06:31:50 pm »
Excellent
ANDY
