Author Topic: sanding sealing and waterproofing  (Read 6895 times)
Philbyuk
« on: May 01, 2020, 08:18:20 pm »
hi there all , not far off sealing  my boat .. got 2 tins of sanding sealer ,but realised they are  cellulose based , i'm going to be painting hull, decks etc with acrylic paint. is this going to be a problem?
also will sanding sealer  help waterproof the wood  inside and out , or better to try something else . suggestions very welcome.
Thanks in advance.
Phil .
JimG
Re: sanding sealing and waterproofing
« Reply #1 on: May 01, 2020, 09:03:22 pm »
Acrylic over cellulose generally not a problem. (the reverse is) However best to leave it for at least a week for the cellulose solvent to fully evaporate before overpainting with acrylic. If you don't the surface of the acrylic will probably crinkle and need sanded back to the sealer. Sanding sealer should waterproof the wood as long as you don't sand through the surface in your preparation before add ing the top coat. For the hull inside I would prefer to use thin finishing epoxy which will soak into the wood and harden the surface.
Jim
Dundee Model Boat club
coch y bonddu
« Reply #2 on: May 01, 2020, 09:41:43 pm »
why take the chance of a reaction simply get some acrylic laquer spray and give the hull 3 coats this will seal the wood for you and defo as Jimg states finishing epoxy on the inside of the hull
Philbyuk
« Reply #3 on: May 01, 2020, 10:58:40 pm »
would fibre glass resin work as good as epoxy resin finish ? a;so if i use the sanding sealer and prime before painting be ok ?
RST
« Reply #4 on: May 01, 2020, 11:22:11 pm »
...been a few posts about sanding sealer recently.  I don't ever remember it being a "covering" or a "coating".  I mean it's fantastic for sealing things "hairy" like balsa or any raggedy edge end grain materials but never heard of it as a full "coating" until recently -when folk are perhaps rightly to say not to, because, maybe its just me but I never saw it used that way before over a big surface on a model?
...Polyester versus epoxy.  Well enough out there already.
Tug Fanatic
« Reply #5 on: May 02, 2020, 08:58:43 am »
would fibre glass resin work as good as epoxy resin finish ?....................
This is my pinion & others will tell you different.
The answer is no!
The other thing is that the epoxy resin that you use needs to be a thin epoxy (a laminating or finishing type). I would never recommend anyone to thin a thick epoxy resin.
tonyH
« Reply #6 on: May 02, 2020, 09:56:43 am »
I know it's a bit of a side issue but does sealing wood with sealer affect the stickability of the wood with either epoxy or superglue?
Tony
Tug Fanatic
« Reply #7 on: May 02, 2020, 10:11:16 am »
Tony
Perhaps you should extend that to any of the common adhesives after sanding sealer. I would identify 2 problems for you to consider:
1. I would observe that there are at least two different types of sanding sealer & their adhesive performance probably differs.
2. I suspect that there is a real lack of data - I certainly have not seen any. Sticking at all and sticking without changing adhesion performance are two different things.
Gardener
« Reply #8 on: May 02, 2020, 10:44:58 am »
Used Deluxe water based sanding sealer with Acrylic paint over it on my Springer  no problems !
Gardener
tonyH
« Reply #10 on: May 02, 2020, 10:52:04 am »
Thanks Tug,
I've got to fit wood (1mm ply or 6mmx1mm mahogany strip) bulwark capping to the edge of a f/glass hull.  The wall thickness is about 2mm so it's fairly good area wise. Normally I'd prep the wood with cellulose sanding sealer before fitting because it would be pretty well impossible to finish the wood properly in place, so........?
Tony
Sorry Gardener but d/l doesn't mention any reaction with the adhesive.
Gardener
« Reply #11 on: May 02, 2020, 10:59:06 am »
Just answering original question !
tonyH
« Reply #12 on: May 02, 2020, 02:55:36 pm »
Sorry old chap,  just got carried away!
 %) Tony
unbuiltnautilus
« Reply #13 on: May 02, 2020, 05:30:56 pm »
I have been using cellulose sanding sealer for more years than I care to remember as first coats ( usually three or more ) on timber/plywood models. Often slightly thinning the first coat for timber penetration. Then followed with spray or brush on primer, finally finishing off with either enamel or acrylic top coats. No adverse reaction problems yet!
The photos show my latest build, LCT-6 from 4mm ply over a glassfibre donor hull. The timber was sanded down and filled first. Then I tried Guild Materials Spray Sanding Sealer. It seemed counter intuitive to have a grain filling cellulose based product in a spray can, it wasn't an issue and it worked very well. The top coats were also from Guild, their light grey enamel aerosol, plus their brush on dark grey enamel. These products seem to be a replacement for the old Flair paints, and I thought I would give them a try. Happy so far.
The rest of the job will be a mix of brush on enamels and acrylics for detailing, plus whatever works for weathering effects.
« Reply #14 on: June 15, 2020, 11:42:08 am »
A question which is troubling me and any advice would be welcome . The hull of my current build is double planked, I have just finished the first planking (Lime ) and am about to sand it . Should I seal the planking before I apply the second planking skin ? the sealer I have at the moment is a shellac base and the glue for the second layer is gorilla.  Thanks
grendel
« Reply #15 on: June 15, 2020, 12:02:16 pm »
If its the gorilla stuff that foams up, the whole point is that it seeps into the grain of the wood to form the bond, i would think that sealing the wood might be counter productive with this glue type.
SailorGreg
« Reply #16 on: June 15, 2020, 02:43:30 pm »
No, don't seal it.  Any sealer (or any other contamination, grease, or whatever) will reduce the effectivenness of the glue you use to apply the second planking.  And if it's not too late, I would use something other than the Gorilla.  It will glue the wood just fine, but you will forever be scraping off the foam that oozes out before applying the next plank.  You will quickly tire of that bit of fun.  I suggest either superglue (if you know you can get the planks postioned correctly quite quickly) which does away with the need for clamps, or an aliphatic resin (Titebond 3 would be my choice) which will give you time to position and clamp the plank before the glue starts to go off.
Greg
« Reply #17 on: June 16, 2020, 01:13:47 am »
It is acknowledged that Gorilla glue is waterproof, but is an obnoxious material to use for fine woodwork
Titebond III  :-))  would certainly get my vote .....it has the highest water resistance [they call it waterproof] of any aliphatic resin....so easy to use and does not stain timber the way Gorilla glue does
If you use any Super glue types, you must select one that is listed as waterproof
Buccaneer
« Reply #18 on: June 16, 2020, 12:52:39 pm »
I can recommend Deluxe Materials Aliphatic Resin glue
john
« Reply #19 on: June 16, 2020, 02:13:38 pm »
Thanks all for your help .  I must apologise that when I said Gorilla glue I was not thinking of the cyano but their wood glue which I assume is a modified cross bond PVA . I have used Titebond III for the frame . My reason for going with the gorilla product for the planking is that the Titebond stains a bit and in gluing up the plank edges I was getting in a bit of a mess and Gorilla wipes off more easily with a damp cloth
Page created in 0.227 seconds with 18 queries.
