Author Topic: Laser cut edges  (Read 2129 times)
rich_morris
Laser cut edges
« on: May 07, 2020, 06:23:19 am »
It's a bit late now, as I've already bonded frames, keel and s couple stringers, but...
How necessary is it to remove/sand back to clean wood the laser  cutcut edges of ply wood?
So far I've only given them a quick rub with glass paper to remove any loose dust, and rough spots where the parts remained attached to the blank.
Re: Laser cut edges
« Reply #1 on: May 07, 2020, 06:37:54 am »
"a quick rub with glass paper"
Yeah, that's what I do.
You have to be careful, as the kits are cut exactly to size so and sanding will make for a sloppy fit.  {:-{
Barry
Re: Laser cut edges
« Reply #2 on: May 07, 2020, 09:48:36 am »
Try wiping/rubbing the blacken edges with  methylated spirits.
JimG
Re: Laser cut edges
« Reply #3 on: May 07, 2020, 10:03:39 am »
The amount of cleaning depends on whether they have used too much laser power or not. Good cutting leaves the edges a light brown colour needing only a light clean. Too much power leaves the edges blackened and needs more sanding to remove the charred wood. Leaving the char on reduces the strength of a glue join as the glue cannot soak into the wood so the bond is purely on the surface.
Jim
Dundee Model Boat club
rich_morris
Re: Laser cut edges
« Reply #4 on: May 07, 2020, 10:06:17 am »
Thanks, I'll keep doing that then. Or at least my son will keep doing that!
rich_morris
Re: Laser cut edges
« Reply #5 on: May 07, 2020, 10:07:44 am »
Thanks, I'll give that a try.
rich_morris
Re: Laser cut edges
« Reply #6 on: May 07, 2020, 10:12:34 am »
Jim
The edges don't seem too badly burnt. Certainly the brown doesn't rub off easily, even with sandpaper.
Edges are brown rather than black.
I'll keep giving them a light clean, unless they look overly burnt.
Page created in 0.546 seconds with 22 queries.
