Author Topic: Brushless ESC's wanted.  (Read 3862 times)
BeeJay UK
  • Norfolk 'n Good
« on: June 18, 2020, 08:01:29 pm »
Evening all.
Can anyone point me in the right direction to find a couple of brushless ESC's at civilised prices.
I thought I was OK as I had a couple of brushless ESC's in the 'spares' box. Both brand brand new but unfortunately they are non-reversing. No Idea why I got those.
I need to run a 1000kv motor hopefully from a 3s LiPo.
Taranis
  • Balne Moor MBC
Re: Brushless ESC's wanted.
« Reply #1 on: June 18, 2020, 08:04:01 pm »
What current rating?
ANDY
Taranis
  • Balne Moor MBC
ANDY
BeeJay UK
  • Norfolk 'n Good
« Reply #3 on: June 18, 2020, 08:33:54 pm »
30A I reckon.
Taranis
  • Balne Moor MBC
« Reply #4 on: June 18, 2020, 08:35:29 pm »
Perfect. They come with mini Tamiya battery connector. You can change it or buy an adapter
ANDY
BeeJay UK
  • Norfolk 'n Good
Taranis
  • Balne Moor MBC
« Reply #6 on: June 18, 2020, 09:02:17 pm »
I think you will struggle to find anything smaller at 30 amps with reverse
ANDY
Subculture
    • Dive-in to Model submarines
Taranis
  • Balne Moor MBC
« Reply #8 on: June 18, 2020, 09:24:04 pm »
Nice and simple then  {-)  how big is the adapter  %%  and a separate Bec even more space.
From an unfamiliar point of view I think photos and a how to would be needed and interesting to know
ANDY
unbuiltnautilus
« Reply #9 on: June 18, 2020, 09:36:47 pm »
https://www.jperkins.com/products/ZTW9030101
Will these fit? Easy set up for forwards only or forwards and reverse. Just down to where you position the throttle stick after setting the high point. Water cooled also, but, they don't have the input power plug or gold connector sockets supplied. You need to supply these.
Subculture
« Reply #10 on: June 18, 2020, 10:00:51 pm »
Try google.
BeeJay UK
  • Norfolk 'n Good
« Reply #11 on: June 18, 2020, 10:02:57 pm »
I reckon this could work, thanks.
Taranis
  • Balne Moor MBC
« Reply #12 on: June 18, 2020, 10:04:43 pm »
That's interesting as it's about the same volumetric size but needs water pipes too
ANDY
BeeJay UK
  • Norfolk 'n Good
« Reply #13 on: June 19, 2020, 11:57:55 am »
Yes, agreed, but it's all down to where the cables come out. To fit where it needs to fit it really needs the cables to come out of both ends not sticking out sideways. The water cooling is an issue though as the hull is double bottomed so difficult to put a scoop in at this late stage.
Charlie
  • I spend far too much time on Model Boats Mayhem!
    • My Youtube Channel
« Reply #14 on: June 19, 2020, 12:18:33 pm »
I can highly recommend these: https://www.componentshop.co.uk/30a-waterproof-brushless-motor-speed-controller-esc.html
I found that water cooling is not required when running a 1100 kv motor on 3S.
DaveM
  • Why on earth do I do this?
« Reply #15 on: June 19, 2020, 01:04:18 pm »
I can agre with that 100%. I've bought five of these over time for use with various 28mm outrunners up to 1000kv on 3S packs. Water-cooling of either the motors or the ESC has never been an issue.
DaveM
Taranis
  • Balne Moor MBC
« Reply #16 on: June 19, 2020, 01:44:30 pm »
They bend flat very easy and are 16mm tall
These have more stock as they are becoming scarce in UK
https://wheelspinmodels.co.uk/i/264636/?gclid=CjwKCAjwxLH3BRApEiwAqX9arXB7ZsKDit_nCIdBrbq8ClS6-jnbeMkrO-z5drSUhZd287VI9wbKTRoCvt8QAvD_BwE
ANDY
BeeJay UK
  • Norfolk 'n Good
« Reply #17 on: June 19, 2020, 03:48:45 pm »
I've taken a chance and ordered a Quicrun from Make it Build it. Fingers crossed it will fit in OK.
roycv
« Reply #18 on: June 19, 2020, 04:41:26 pm »
Just a thought but if you have a parallel running servo with a microswitch capable of handling the current.  If when going forward it moves but does nothing and when you want reverse it changes the microswitch over and reverses any 2 of the 3 wires to the brushless motor then you can make use of them rather than bin them.
Roy
BeeJay UK
  • Norfolk 'n Good
« Reply #19 on: June 19, 2020, 04:51:22 pm »
Oh I wasn't going to bin them, I am far too mean to do that.
I have got a couple of R/C switches going spare which I could use to trigger a DP changeover relay. I've probably got a low voltage relay if I dig deep in the garage.
Taranis
  • Balne Moor MBC
« Reply #20 on: June 19, 2020, 09:18:46 pm »
I just bought two more myself after reviewing the models I’ve yet to build
ANDY
« Reply #21 on: June 20, 2020, 08:44:49 am »
Roy
If space is at a premium a microswitch plus servo will not work.  The "micro" in microswitch indicates switching time rather than size - for their current carrying ability, they tend to be quite large.  Switching ability might not be a problem, it should only change state when passing through neutral, when the motor and ESC are hopefully at rest.
Page created in 0.691 seconds with 19 queries.
