Author Topic: Motors for Italeri S-100  (Read 2654 times)
« on: August 02, 2020, 12:14:35 pm »
Which motors x2 and about 380 size but Not 380 or 385's  would be  suitable  for Italeri's  s-100 Thanks
Re: Motors for Italeri S-100
« Reply #1 on: August 02, 2020, 03:13:07 pm »
« Reply #2 on: August 02, 2020, 04:01:12 pm »
Whats that got to do with Motors?
« Reply #3 on: August 02, 2020, 04:17:59 pm »
Nothing... but it gives the size and layout for everybody else.   :P
« Reply #4 on: August 02, 2020, 04:54:11 pm »
OK but 50/50 on any commission
« Reply #5 on: August 02, 2020, 05:14:16 pm »
  Fair enough!   {-)
T888
« Reply #6 on: August 02, 2020, 07:59:44 pm »
In my S100 I used three speed 400 motors
Regards David
« Reply #7 on: August 02, 2020, 11:08:21 pm »
Thanks  if I had 3 props I would try another 300  do you think the 400's are  more powerful than the 300/385 they also have to be nearly the same diameter
T888
« Reply #8 on: August 03, 2020, 06:25:11 am »
Hi, I believe 380/ 400 there is no difference would assume 385 is the same but the tech bods with correct me if I’m range. But  have a look at the posting may help https://www.modelboatmayhem.co.uk/forum/index.php?topic=11713.0
Regards David
« Reply #9 on: August 03, 2020, 10:08:47 am »
The 380 is the basic design with 3 poles, giving lots of speed but not a lot of torque.  A 385 has 5 poles (hance the 5 at the end of its number) which reduces its speed, but increases torque and improved slow speed control.  400 series motors are the exact same size as 380 motors, but are later versions with the number range changed to make life simpler (allegedly) for marketing people.  Usually they have more modern, more powerful magnets and "might" be better engineered.  A lot can happen in the space available, but at some point everything becomes a compromise game.  Thicker wire means fewer turns for more speed at the cost of more current which means bigger brushgear which there might or might not be room for with the size of armature wanted.  Stuff like that.
I used to like the "Litespeed 400" run at the max voltage that was on the label for fast boats.  No idea if you can still find them.
« Reply #10 on: August 03, 2020, 10:58:02 am »
Thank you Both
Page created in 0.211 seconds with 17 queries.
